Author Topic: It's possible to use?  (Read 728 times)
Speedx
  • Country: lb
« on: September 02, 2022, 05:38:22 AM »
Hello i want to use my Tesla turbine to run an ac single phase alternator 5kw.it is possible?
Is there a formula to know how many air pressure you need to run a 1kw generator?
JW
  • Development Manager
    • Flashsteam.com
Re: It's possible to use?
« Reply #1 on: September 02, 2022, 07:20:03 AM »
Tesla turbines are controversial in there applications. Generally they very high speed in there applications. Most of the alternators used in practice here are low speed.
Some questions- how many disks will you use and what type of nozzle's will you use. I have a lot applications and have experience with steam engines.
JW
    • Flashsteam.com
« Reply #2 on: September 02, 2022, 11:36:01 PM »
 2157
040317a
14993-0" alt="" class="bbc_img" />
JW
    • Flashsteam.com
« Reply #3 on: September 03, 2022, 12:30:22 AM »
KA57
Weave got bigger problems than the images issues. Flavio hates our host and I just don't think we can recover from that.
Speaking of the host they just directed me to recover/ Point MX record bunch of other stuff and I have control again. I remember solving this problem before way back.
TechAdmin
  • Country: it
« Reply #4 on: September 06, 2022, 08:17:10 AM »
That one you messed up the upload, you tried to copy/paste it from somewhere.
Whenever I try to upload it always works fine...
14995-0
Speedx
  • Country: lb
« Reply #5 on: September 06, 2022, 08:32:42 AM »
I want to use tesla turbine to run AC alternator single phase 5kw.i didn't build a previous tesla turbine. So i don't have a clue, about size of disk and the number of them, size of nozzel. General idea is to use it for run allready made ac alternator that run on 1500 rpm. I want to know how many hours can run If i have a 100L compressed air?
I want this concept to be applied to diy axial flux generator.
It's working as looping system.
bigrockcandymountain
« Reply #6 on: September 06, 2022, 08:52:14 AM »
At 5kw you will only have a couple minutes of power from 100l of compressed air.  If you think about it, a 5kw compressor would fill a 100l tank in about a minute.  The same applies when going the other way.
Speedx
  • Country: lb
« Reply #7 on: September 06, 2022, 10:13:13 AM »
Ok thanks.
« Last Edit: September 07, 2022, 08:46:30 AM by Speedx »
