Author Topic: Jim's Cool Things  (Read 1415 times)
MattM
Jim's Cool Things
« on: May 13, 2023, 06:51:15 PM »
I am amazed how simple Jim's design is.  It is basically using flag power in a VAWT.
https://www.youtube.com/watch?v=m4bkOIApDiA
Re: Jim's Cool Things
« Reply #1 on: May 13, 2023, 09:19:53 PM »
Yes a lot of things will spin if you point a fan at one side and not the other.
Does it run outdoors?
With a generator or other sort of load?
clockmanFRA
  • Country: fr
    • Renewable Energy creation
« Reply #2 on: May 14, 2023, 04:33:21 AM »
His Vid shows Old concept, modern twist.
15455-0
3 Hugh P's 3.7m Wind T's (15 years) .. 5kW PV on 3 Trackers, (11 yrs) .. 25kW PV AC coupled to OzInverter MINI Grid, back charging AC Coupling to 48v 1300ah batter
MattM
« Reply #3 on: May 14, 2023, 10:23:54 PM »
He shows a clip with the fan pointed centerline early on and then the completed array running in the wind.  He certainly could have cut substantial weight from his circular rotor ends.  But even with the high weight it worked pretty well in light wind.
« Reply #4 on: May 15, 2023, 08:45:15 AM »
I liked the fact he wasn't trying to prove Betz's limit wrong.
It'll be interesting to see it running with a gen attached too, should be good for a bit of battery charging.
