Author Topic: Ryobi lithium battery hack  (Read 1262 times)
« on: June 27, 2023, 01:37:51 PM »
I got 2 40v Ryobi batteries that were 10 years old for salvage. The riser tab labelled + is the true positive end of the pack, but the riser labelled - is not. The true negative end of the pack is on the circuit board. If you solder a wire to that spot on the board and run it out of the case you can force charge the pack without opening the case again. You can't use a Ryobi charger to do that, but for about $20 there are 42v power supplies that are simply off or on with no logic check.
The force charged battery did not work reliably in my tool. I checked the + and - riser pins and saw only 16v. If I grounded the true battery - to the heat sink (which is the true board ground) there was a brief mild spark and then the + and - risers showed 1/2 volt less than the true pack voltage.
1/2v is the common drop for a diode. Somewhere on the board is a failed diode. A 40v pack is two 20v packs tagged in series inside one case.
I added another wire behind the heat sink and ran it out of the pack just like the true battery ground. I put quick connects on each external end of the wires and when I want to use the tool, I connect the 2 wires so the tool sees the correct voltage. I don't have to open the pack anymore to either charge or use the pack.
When charging or storaging the two external wires are unplugged from each other. There is a 0.2ma parasitic drain otherwise.
Re: Ryobi lithium battery hack
« Reply #1 on: June 28, 2023, 11:34:18 AM »
Have to keep this in mind... I have 4 of them to power my chainsaw, weed trimmer, and a 1800 watt inverter.
Jackir
  • Country: vn
« Reply #2 on: November 15, 2023, 01:21:12 AM »
It's always cool to see folks getting creative with their tools. Sounds like you've got a good workaround for charging and using the pack without having to open it up each time.
