Author Topic: Cheap coil winder  (Read 4203 times)
SimonMester
Cheap coil winder
« on: July 08, 2023, 11:29:04 AM »
So, would some like this: https://www.ebay.co.uk/itm/272260176256?epid=1372418956&
be helpful to wind coils, or is it too cheap to be much of an improvement over doing it by hand?
I have iron cores 100mm by 11mm, would it even be able to wind copper nicely onto that "uneven" shape? As its not just a nice round thing.
Never used one of these so I'm just not sure what to expect. I'm using 0.6mm wire.
Discord: SimonMester#8982
Re: Cheap coil winder
« Reply #1 on: July 08, 2023, 12:26:04 PM »
It's designed for very fine wore like you find in a speaker coil... if you wind heavier than 18 gauge I think it will fail. 18 may even be to much for it...
SimonMester
« Reply #2 on: July 08, 2023, 12:31:07 PM »
Any tips for hand winding the wire? Not sure how to "straighten" it as it unwinds. As it has a natural 'bend' in it from being wound on the reel of course.
Wasting a lot of space, and pushing it around or trying to flatten it, the wire is too strong for that.
Suppose I could always just try to wind the next layer tightly over the one before it to squish it down as much as possible.
« Reply #3 on: July 09, 2023, 09:58:03 AM »
I made a coil winder from am old variable speed electric drill .
 Added a turn counter i bought separately.
 i keep a threaded rod in the chuck and build a coil jig on he threaded rod.
 its all set up on its own mahogany plank . and has the capability of turning single wire  or 3 in hand coils.
its a mechanical counter and if i built another i would use a magnetic turn counter rather than the noisy mechanical one .
« Reply #4 on: July 09, 2023, 01:26:14 PM »
You can do the math and get a rough idea of how much wire you will need. Cut that off the spool(add a little extra for oops I was wrong) then attach one end to something heavy, wrap the other end around a dowel then grab the dowel and pull. It will straighten the wire. Commercial winders do this via wheel pressure and if you watch a machine it has a straight section before the winder to remove any curve memory.
Yes the above wastes a little wire... can save that for jumpers between coils.
SimonMester
« Reply #5 on: July 10, 2023, 09:38:44 AM »
I feel like I'd rather build a hand wound machine first. Maybe I'll give that a go. I just want to wind a couple simple coils, one by one, make sure they are straightened out so I can wind them nicely.
Do you know of any general outlines/schematics I could inspect? As I have never made one, would be nice to see.
« Last Edit: July 10, 2023, 10:23:22 AM by SimonMester »
SimonMester
« Reply #6 on: July 10, 2023, 09:39:39 AM »
Thanks for the reply, it's given me some ideas. I might DIY some kind of wire straightener with wheels, and then just wind the coils with a crank after that section.
Also grats on 3k comments. :)
