Author Topic: River driven power  (Read 2917 times)
(unknown)
River driven power
« on: January 20, 2010, 08:42:58 AM »
I have determined that a Savonius type windmill strengthened up to run in water at a 9 knot current would be best for me. I know I will have high torque and was thinking of just gearing up and running 2 high output car alternators. I don't know if I should change my thinking and make a large home built alternator. I will be off grid and this will be my only source of power so I want it to be simple, reliable and last a long time. If any one has any ideas or comments I would be very grateful.
« Last Edit: January 20, 2010, 08:42:58 AM by (unknown) »
wdyasq
Re: River driven power
« Reply #1 on: January 20, 2010, 11:00:42 AM »
You may want to look at the Gorlov Turbine.
« Last Edit: January 20, 2010, 11:00:42 AM by wdyasq »
clflyguy
« Reply #2 on: January 20, 2010, 04:15:36 PM »
9 knots!! You are in business my friend. I was already designing this for the creek in my back yard, my easement only goes to the middle of it so no damming in my case either. My creek only flows about 6 mph. This thing is to be built on a budget so the blades or paddles are 1/3 sections of 6" PVC, the wheels are epoxy saturated exterior plywood, the center shaft is 1-1/2" galv. fence tube, bearings are probably going to be homemade from 1/2" nylon sheet. Otherpower style axial flux alt wound for 24V and bicycle provided chain and gear set. Floats are stacked 2" thick layers of white polystyrene foam hotwire cut to simple hull shapes under a 2x8 frame w/ 2x8 cross members. The foam displaces 125 lbs per cubic foot, so you can weigh your components as you build to figure how many cu. ft. of foam you need... Have fun, invite friends!
« Last Edit: January 20, 2010, 04:15:36 PM by clflyguy »
clflyguy
« Reply #3 on: January 20, 2010, 04:19:36 PM »
OK, the picture didn't post with it -- undershotsmall.jpg -- can somebody fix it please?
« Last Edit: January 20, 2010, 04:19:36 PM by clflyguy »
« Reply #4 on: January 20, 2010, 04:50:01 PM »
« Last Edit: January 20, 2010, 04:50:01 PM by TomW »
clflyguy
« Reply #5 on: January 20, 2010, 09:13:41 PM »
Thank you, Tom
« Last Edit: January 20, 2010, 09:13:41 PM by clflyguy »
electrak
« Reply #6 on: January 23, 2010, 03:11:50 PM »
you must have lots of trillium where you are. thats some heavy water, it's about 60Lbs per cubic foot here.
Wish I had hydro or wind or solar, but not stream, ave. wind is about 3mph, and I don't see the sun until 10:00 then it's gone by 3:00, north side of a hill and trees
« Last Edit: January 23, 2010, 03:11:50 PM by electrak »
clflyguy
« Reply #7 on: January 26, 2010, 03:45:29 PM »
Whoooops! Totally plugged in the wrong number there- thinking of saturated soil, 62 lbs. cu. ft. for fresh water is correct. -Sorry, senior moment here...
« Last Edit: January 26, 2010, 03:45:29 PM by clflyguy »
