Author Topic: Expanded Scale Voltmeter  (Read 4558 times)
commanda
« on: September 14, 2004, 11:09:45 PM »
This is the circuit diagram of the voltmeter I just built.
circuit in pdf format
I built it on a little round pcb & bolted it directly to the back of a MU45 1mA meter. I photo-shopped the meter face to read 10 to 15 volts.
Most of the circuits I have played with tend to become non-linear at the lower end of the scale. This circuit is absolutely linear. Using an LM358, the current drain is approx 1.2 - 2.2 mA. The ICL8062 gives 1.2 volts. The dual op-amp could be replaced with a TSM103, which has the reference voltage built in. You could then do away with U2, R6, C3. U2 could be any reference source; zener diodes, even an LED. But a precision reference is more stable.
The box in the bottom left explains the basic math. For my implementation, the voltage at point B is 1.2 volts. So the voltage at point A needs to be 1.2 volts when the battery is 10 volts. There will then be zero volts across R1 & R2, so no current will flow in the meter. When the battery voltage is 15 volts, the voltage at point A will now be 1.8 volts, so there will be 0.6 volts across R1 & R2. If R2 is adjusted so R1 + R2 = 600 ohms, then the current through R1 & R2 (and hence the meter) will be 1mA.
As built photos tomorrow. Questions welcome.
The LM358 & ICL8062 were on hand, hence their use.
« Last Edit: September 14, 2004, 11:09:45 PM by (unknown) »
Old F
Re: Expanded Scale Voltmeter
« Reply #1 on: September 16, 2004, 06:11:38 PM »
Top notch  work as always
Short sweet and to the point with small parts count.
Have you ever tried or heard of ground plane construction some times called dead bug ?
Where you  places an IC with the pins sticking up in the air looks like a dead bug on a copper clad  circuit board  and the board becomes the ground point  for the circuit. Not pretty  but it works.
Not every  body  is set up for PCB work. I have been playing with the bit and bobs  and photo  etching  boards for years heck when I was in school we had these thing called tubes  :  )    Where are you getting your meters  and parts ?
Your projects are great for folks who want to get there feet wet in electronics construction and have something use full when there done.
Keep up the great work !
Old F
« Last Edit: September 16, 2004, 06:11:38 PM by Old F »
commanda
« Reply #2 on: September 17, 2004, 06:17:27 PM »
Never heard of ground plane construction, but I have used Xmas tree construction. And a variation where you use plain old cardboard, punch holes through for the component leads, and use the pigtails on the underside of the cardboard to make connections.
I built the prototype of this circuit on veroboard. The pcb I made using the "join the dots with a texta" method.  Did the layout with Protel autotrax, printed it, layed it over the blank pcb, center-punched the holes & drilled them. Them drew the tracks by hand with a CDR marker.
Parts I get from Jaycar or Farnell. I'm in Australia.
« Last Edit: September 17, 2004, 06:17:27 PM by commanda »
jacquesm
« Reply #3 on: September 17, 2004, 06:24:01 PM »
that is one hell of a clever way to make a pcb, I'll steal that trick if you don't mind !
I'd hate to do anything a little larger like that, but for small projects it's probably the fastest way of doing it that I have ever heard of.
ground plane construction (above 'plain' pcb material or copper) is very common in HF prototyping. You use a long strip of pcb, solder on little vertical slats to separate the various stages and pass signals & power from one stage to the next using pass-through caps (soldered into the slats) and ferrite beads. Works wonders, but it has a few drawbacks (microphony and mechanical instabiliy) which make it pretty hard to build something two times and get exactly the same performance.
It's quick though, and much easier than designing a pcb for an HF design.
« Last Edit: September 17, 2004, 06:24:01 PM by jacquesm »
commanda
« Reply #4 on: September 20, 2004, 06:21:46 PM »
And here's the promised photo's.
« Last Edit: September 20, 2004, 06:21:46 PM by commanda »
