Author Topic: Test  (Read 980 times)
Muffloj
Test
« on: October 11, 2004, 09:12:40 AM »
« Last Edit: October 11, 2004, 09:12:40 AM by (unknown) »
Muffloj
Re: Test
« Reply #1 on: October 11, 2004, 09:15:09 AM »
Is there a way to delete some of my diary files
« Last Edit: October 11, 2004, 09:15:09 AM by Muffloj »
hvirtane
    • About Solar Cooking
Re: Test
« Reply #2 on: October 12, 2004, 03:14:03 PM »
It seems to be the case that you
cannot edit or delete your
textual inputs yourself.
But if the problem is with
the picture then there is one way:
You can upload there a new picture with
the same name and it will appear there
at the board instead of the picture,
which had the same name.
But if your code pointing
to that picture is wrong,
you can't edit that yourself.
It is best to try first
always with 'preview'.
« Last Edit: October 12, 2004, 03:14:03 PM by hvirtane »
hvirtane
Re: Test
« Reply #3 on: October 12, 2004, 03:24:27 PM »
I think that you should try uploading
there in the server a new file
called 'Jpgsk1.jpg'
and make first sure
that that file is a true
'jpg' picture file, which works with
your own computer and
with the web-browser,
which you are using.
I think that your original
picture is corrupted somehow.
At least it doesn't work
with my machinery.
« Last Edit: October 12, 2004, 03:24:27 PM by hvirtane »
Muffloj
Re: Test
« Reply #4 on: September 07, 2005, 09:26:55 AM »
Did it work?
« Last Edit: September 07, 2005, 09:26:55 AM by Muffloj »
