Beautiful!
Any advice on how to avoid a concrete foundation though? And how to keep out the bugs too. I know of 100+ yr old log homes still standing, they did not have concrete trucks or blocks when they built those original homes. Everything I find on log homes says concrete foundation, or has concrete blocks all the way around and under.
I am thinking of building one on piers myself for above ground and also a dug home into the side of a small hill right next to it. For the dug home I may just bury my trailers houses and build a roof to support the dirt.
We have carpenter ants, wood roaches, termites, etc.. all the normal bugs that eat wood! Central USA. But I figure if the pioneers could build an all wood cabin then I should be able too also and I have trees needing cut, they die out rot and fall anyway here when getting much larger/older. Second growth after heavy cutting way before I bought the place. These need removed then replanted correctly, the wild growth is killing itself out.
Most are 1-2 foot dia as far as what still seems solid. Mostly oak. Several types.
The white oak doesn't seem to be so bad so I will probably let it stand and cut the others. Would rather not just burn it for fire wood though. Some of it is reffered to as black jack and when dried is nearly hard as a rock. Mostly what I think I will be using, so I would need to work it while green. Dried maybe it could be split, but it dulls a chainsaw fast it can get so hard.
Any advice on getting started with the first course. I'll start cutting it in about a week since I plan to be using the scrap (small limbs) for fire wood this year. Anything large enough to be usefull I will be saving for the home and furniture.
I have (about 20years ago) built kit log homes with a contractor, all prefabbed logs and of course concrete foundation on those. They were drilled and spiked also.
For spikes I will be blacksmithing my own from rebar and some other steel.
I have alot of good ideas, but getting the first course started will be my biggest problem, though I'm sure I will have many as I go!
I love that front porch on your house, if you don't mind I think I will borrow that look for mine also.
