Author Topic: Prop Comparison on Ametek 40v  (Read 5092 times)
Peppyy
« on: January 06, 2005, 11:29:42 PM »
Finally some wind! Gusty as it may be.
I had a chance to test the ZubWoofers. So far I am rather impressed.
Here are a few shots of the state of the art test equipment in action.
3 MPH wind and 5.5 volts. That is a lucky shot. It is
usually only around 3 volts.
Another lucky shot, usually around 12 volts.
This one really made me smile!
Here is a comparison chart I made for my current tests.
All readings were with approximately a 10 watt load.
Since I still haven't hit 15 MPH with the double zub that is just a
guess.
As you can see they out perform my original 21" prop.
My next step is to build a real set of wooden blades and
see how they work. I am sure a decent height mast would
help the power output also.
« Last Edit: January 06, 2005, 11:29:42 PM by (unknown) »
Re: Prop Comparison on Ametek 40v
« Reply #1 on: January 06, 2005, 05:11:23 PM »
what about a picture of the zub?
what are zub blades?--homemade blades...
« Last Edit: January 06, 2005, 05:11:23 PM by hiker »
zubbly
« Reply #2 on: January 06, 2005, 07:12:48 PM »
Hey Peppyy!
nice to see some one doing some serious testing of those zubwoofer blades.  :-)
please keep us all posted with your tests and findings.
have fun,   zubbly
« Last Edit: January 06, 2005, 07:12:48 PM by zubbly »
Peppyy
« Reply #3 on: January 06, 2005, 07:17:01 PM »
Here is the design I used to make mine.
http://www.fieldlines.com/story/2003/11/11/172721/53
I made a wooden hub that fit between 2 blades, (No photos yet cause
I was in a hurry). I will get some when it's light out.
Here is the prop I call Sputnic.
http://www.fieldlines.com/story/2004/11/24/17554/089
The other was just a plastic 14" 3 blade fan.
« Last Edit: January 06, 2005, 07:17:01 PM by Peppyy »
« Reply #4 on: January 06, 2005, 09:41:18 PM »
Hey Peppyy
Of course I have to get in on this thread too.
I would like to see some pics of your ZubWoofer blades too, and some details like.
Blade length
Pipe diameter
I have a ZubWoofer bolted to a TV mast and tied to my fence outside. I love to watch it spinning. It's a 42 inch blade made from a 4 inch pipe. A 40° hub angle and a 7° tip angle. It's not hooked up to anything, it's just proving a concept.
I have obtained a syrup barrel from the Coca-Cola bottler next to where I work. It's about 20 inches in diameter and 4 feet tall, plenty thick and hard. This will be my next Blade Project and will probably end up driving my wind genny which is now about 95% complete. Well it's really finished but I have to fix a little mistake causing my airgap to be to small, about a 3 hour fix.
http://www.fieldlines.com/story/2004/4/4/164552/3003
Good luck and keep us posted to your progress . . .
« Last Edit: January 06, 2005, 09:41:18 PM by wooferhound »
« Reply #5 on: January 06, 2005, 09:45:27 PM »
I had ment to include this picture with my last comment...
« Last Edit: January 06, 2005, 09:45:27 PM by wooferhound »
Peppyy
« Reply #6 on: January 07, 2005, 05:37:46 AM »
Well it's some sort of testing alright. I don't know how serious it is.
I have noticed at higher wind speeds, above 10MPH there is a balance problem.
My tower is only 16 feet so the wind shifts rather quickly
but it is at the height of my anemometer. If I get any steady
wind the blades seem to respond with a rapid steady rise in speed.
I basically took the drawing and the photos and made one that
looked about the same as that. Traced that one to make the second
one and then designed a hub to go between them. Since I didn't have
the hub I ran a single blade for a week. It started around 5 to 6 MPH
and then spun up fairly quickly but it made the yaw really jerky.
As you can see, the double setup starts rotating at around 3MPH.
at about 8MPH my 12v fl trouble light is full bright so these blades
have the best low wind performance of any I have tested so far.
I don't know yet how they will be with a decent load because the
nature of the wind in this location being so sparatic. Today it is
running from almost nothing to gusts around 15MPH from the N and E amd NW
and such. I guess if I cut a couple trees and put up a tower I could get
some useable power out of it.
« Last Edit: January 07, 2005, 05:37:46 AM by Peppyy »
Peppyy
« Reply #7 on: January 07, 2005, 05:54:55 AM »
Depending on what you have for wind in your area it sounds
like your genny should work really well. The blades on the Ametek
are 48" out of 4" green pvc pipe. Just threw my kill switch
and shorted the genny and went out to watch it. The blades start
turning slowly around 6 MPH and even though I wasn't out there long
they got up to around 120 to 150 rpm in a gust. Can't load it any
more than that.
I would say that is a fair amount of torque. I know that when I
put the blades on the motor was really hard to turn with it shorted.
If I get a chance today I will hook up a 50w 12v halogen and see if
it will light that. Haven't got a lot of test equipment around, (Yet)
so I make due with what I have :)
« Last Edit: January 07, 2005, 05:54:55 AM by Peppyy »
Peppyy
« Reply #8 on: January 07, 2005, 09:16:15 AM »
Here are a couple shots of the Double Zubwoofer.
The blocks in between are 2 by stock keyed together at
90 degree angles. there is a 3/8" x 5" lag bolt holding them on.
The bolt has a couple spacers because I should have had
a 4- 1/2" lag bolt.
The motor shaft has a 1/2"x3" pipe nipple over it, origionally to
mount the Sputhic prop with a 7/8" center hole. Inside the prop end
of the nipple is a "Led anchor" which aren't made of led anymore.
The wind let up just long enough to get a fairly sharp photo. From
this
angle you can't see the other block which supports the outer blade
lengthwise.
This was about a 10MPH wind. In my digital viewfinder it looked
like it had 12 blades. It has been snowing and blowing until just a
little while ago, hense the snow in the center.
« Last Edit: January 07, 2005, 09:16:15 AM by Peppyy »
« Reply #9 on: January 07, 2005, 09:47:36 AM »
The Sputnic is what impresses me.
And the 14" fan comes into its own at higher wind.
Good work!
« Last Edit: January 07, 2005, 09:47:36 AM by ghurd »
rotornuts
« Reply #10 on: January 07, 2005, 08:05:53 PM »
I agree Considering sputnic is less than half the diameter of the zubwoofers. I'd love to see a bigger sputnic. Real wind data of the zubwoofers in higher winds might change that though.
« Last Edit: January 07, 2005, 08:05:53 PM by rotornuts »
« Reply #11 on: January 07, 2005, 08:19:14 PM »
Double Cool !
              Thanks for posting the photos and info.
    Your connecting block between the blades gives me even more ideas.
« Last Edit: January 07, 2005, 08:19:14 PM by wooferhound »
Peppyy
« Reply #12 on: January 08, 2005, 07:55:59 PM »
Every time I look at my mini 9" with 8 blades
and see how fast that one is turning it makes me
want to build another one with 8 blades.
 Maybe a little bigger too.
Just have to find the material.
« Last Edit: January 08, 2005, 07:55:59 PM by Peppyy »
« Reply #13 on: January 17, 2005, 09:34:39 AM »
Don't know if you will see this.
Maybe the ZubWoofers are a tad too long to get enough RPMs for the Amatek?
It would be interesting to see a 24" or 30" set of Zubs for comparison.
« Last Edit: January 17, 2005, 09:34:39 AM by ghurd »
Peppyy
« Reply #14 on: March 05, 2005, 12:07:57 PM »
Now that the setup is geared 2 to 1 it seems to be about the right power ratio. Might be able to improve it if I could get the startup speed a little lower.
Yup, I saw it :)
« Last Edit: March 05, 2005, 12:07:57 PM by Peppyy »
