Finally some wind. Seems to be feast or famine lol.
I posted this in the old diary but I thought a few of you might like an update.
The mill is actually doing some work. Looks like anything above 10mph will now be useable. When it started getting windy this morning I turned on my digital meter and watched the no-load get as high as 32 volts so I had to find something to charge.
A while back, big-lots had a nifty coleman powermate light/compressor/12v, accessory pack. Not a jumper pack. I am forever blowing up tires on my old tractors so I bought it. Turns out that the charge jack that you plug the walwart into must have a diode bridge built in, probably to eliminate the possibilty of reversing the polairity. Well guess what. That little bugger charges just fine off that little mill. I just have to keep an eye on it for now so it doesn't overcharge.
When I plug it in it brings the genny voltage down between 14 and 16vdc until the wind lets up and then there is no bleed back at all. The jack also disconnects the battery from everything else so I have to unplug it to test the unit. Might have to get a couple of those jacks and put them in my booster and jumper packs, without the disconnects.
I should also plan on getting some real bearings and such for the next rebuild session. Anybody got a 4 foot diameter plastic bucket lid?
Pep
