I normaly do the rpm test first. Not this time. I knew this alt would need high rpm in the wind so I through a 2 blade together real fast. It a 49" Jerry blade with Mike mods.
Then I did the rpm test the following day. i used the same battery bank for the load in both tests. The battery bank in my S-10 wind test truck.
This is why you'll see the rpm test stuff setting on the ground next to the test truck.
I think the rpm test will also indicate the blade rpm. I'm thinking if I get 3 amps at 1125 rpm that 3 amps at 20 mph would mean the blades is spinning at 1125 rpm?
Wind test rpm
- mph 1 amp, 860 rpm 1 amp
- mph 2 amp, 955 rpm 2 amp
- mph 3 amp,1125 rpm 3 amp
- mph 4 amp,1237 rpm 4 amp
- mph 5 amp,1371 rpm 5 amp
- mph 6 amp,1508 rpm 6 amp
- mph 8 amp,1793 rpm 8 amp
It did 7 amps at 1647 rpm. Strange how it would go up 1 amp for each 5 mph.
These are very pore #s and low output but this was just a study test.
The blade was very smooth and fast. The fast was do to not much of a load from this very week alt.
This is the wind test.
This is the rpm test using the light dimmer/motor speed control.
