Author Topic: easy pvc blades  (Read 2109 times)
georgeodjungle
easy pvc blades
« on: October 03, 2005, 06:47:28 AM »
get some pipe "the gray conduit pipe seems to last longer"
48" should be the max,that might even be too much.
cut along stamped writing
at one end mesure over 4" and the other end 1" make line, cut.
mesure 4" form 1" side make line, cut.next thing ya know ya got a hole stack of 5
weigh them and grind then dowm to the lightest,
make them all the same.
and there you go.
i knew that weight watchers scale would come handy some day.
« Last Edit: October 03, 2005, 06:47:28 AM by (unknown) »
pyrocasto
Re: easy pvc blades
« Reply #1 on: October 03, 2005, 12:54:25 AM »
What's the pipe diameter on these?
« Last Edit: October 03, 2005, 12:54:25 AM by pyrocasto »
georgeodjungle
Re: easy pvc blades
« Reply #2 on: October 03, 2005, 01:19:34 AM »
sorrie
get some 4"
4" di seems to work the best.
and thats what i'm using.
i've tried from 2" to 6"
« Last Edit: October 03, 2005, 01:19:34 AM by georgeodjungle »
fukenfooser
Re: easy pvc blades
« Reply #3 on: October 03, 2005, 08:27:40 AM »
Hello
Please explane this again.
Make a mark for center at each end, start cut 4" from mark ? to the left? or counterclockwise?
cut to a mark 1" from center mark on same side, (counterclockwise)?
Anyway please explane because I'm a newby and am researching.
ff
« Last Edit: October 03, 2005, 08:27:40 AM by fukenfooser »
georgeodjungle
Re: easy pvc blades
« Reply #4 on: October 03, 2005, 02:35:52 PM »
4" at one end and 1" at the other.like a trapeziod or a pvc blade.
« Last Edit: October 03, 2005, 02:35:52 PM by georgeodjungle »
Re: easy pvc blades
« Reply #5 on: October 03, 2005, 08:44:36 PM »
and lets not forget the one piece design . . .
http://www.fieldlines.com/story/2003/11/11/172721/53
« Last Edit: October 03, 2005, 08:44:36 PM by wooferhound »
Re: easy pvc blades
« Reply #6 on: October 04, 2005, 01:52:23 AM »
After much trial and error.  Mostly error.
I wouldn't suggest much deviation from the one piece design angles, regardless of the blade diameter. Even with 3 or 5 or whatever blades.  There is always room for improvement, but those 'puppies' work pretty well as is. (pun intended)
Easy newbie blades. Even I can make them!
« Last Edit: October 04, 2005, 01:52:23 AM by ghurd »
Devo
Re: easy pvc blades
« Reply #7 on: October 04, 2005, 11:31:06 AM »
Do you have any finished pics , with them mounted on a hub?
thanks
Devo
« Last Edit: October 04, 2005, 11:31:06 AM by Devo »
georgeodjungle
Re: easy pvc blades
« Reply #8 on: October 04, 2005, 12:18:55 PM »
i think the one peace is out of my capability.
the hubs are 2 peace radiator fans.
ones off a  71 corn binder and the bigger one is a napa flex fan.
i didn't have a cammera when i did'em.
i'm making some pvc gennys for some friends in november,i'll take some pics as i go.
and try to explain my self better.
« Last Edit: October 04, 2005, 12:18:55 PM by georgeodjungle »
georgeodjungle
Re: easy pvc blades
« Reply #9 on: October 04, 2005, 12:48:20 PM »
oops the pic of the lil 5' genny didn't turn out let's try?
there she is!
« Last Edit: October 04, 2005, 12:48:20 PM by georgeodjungle »
Jon Miller
    • Otherpower UK
Re: easy pvc blades
« Reply #10 on: October 04, 2005, 03:28:30 PM »
Sorry to say i cant find it but there is a program that does all the workingout for you.  which i would like to have as i have lost it on this pc.  pleas lets find it it was and is worth the effot. any who its late hear i am of to bed.
« Last Edit: October 04, 2005, 03:28:30 PM by Jon Miller »
