Author Topic: test post  (Read 1133 times)
ubud
test post
« on: December 06, 2005, 02:56:03 PM »
test post picture:
« Last Edit: December 06, 2005, 02:56:03 PM by (unknown) »
johnlm
Re: test post
« Reply #1 on: December 06, 2005, 09:33:33 AM »
Looks like it worked ok.  Pic size ok, loaded fast etc.  Any particular reason for the camo colored blades?
« Last Edit: December 06, 2005, 09:33:33 AM by johnlm »
The Professor
Re: test post
« Reply #2 on: December 06, 2005, 09:52:02 AM »
   Looks like your blades have twist, good. Please tell us about the construction. Looks like they may be glass skinned with a wire trailing edge.
« Last Edit: December 06, 2005, 09:52:02 AM by The Professor »
ubud
Re: test post
« Reply #3 on: December 06, 2005, 10:01:48 AM »
old alum sheet. trying stressed skin on tube for blades. base is 1/2" emt. with 5/8
grade 5 x 8" bolt with head cut off hammered into tube for root of blade.
root is 9" @19 deg. tip is 4" @2 deg.
center plates are 10 ga. 1/4x20 grade 8 fastens blades to plates.
total rotor weight... 21.5# dia. 8.5 ft
will monotior rpm with modified optical tach. 2 3/8 x 1/16 neos on back of hub. w/pickup coil.
wind speed, bicycle anemometer
alt.= dual plate 12 pole 9 coils star. shaped mags from ed, mount from hugh, i'm hopeing for a good mix, time and mother will tell the whole story.
Frank
« Last Edit: December 06, 2005, 10:01:48 AM by ubud »
Re: test post
« Reply #4 on: December 06, 2005, 10:27:42 AM »
Another test
Looks to be a nice profile, I just hope aluminium holds together.
« Last Edit: December 06, 2005, 10:27:42 AM by Flux »
Re: test post
« Reply #5 on: December 06, 2005, 06:38:22 PM »
i dou"t if those metal rods will hold up--your blades will end up bending back and hitting the pole--or worse..thats a lot of blade just for on rod to hold ridged..
you could bury those blades in wood , like my angled wooden hub..
« Last Edit: December 06, 2005, 06:38:22 PM by hiker »
