Author Topic: Hard to decide  (Read 1550 times)
Dan_NS_CAN
Hard to decide
« on: February 21, 2006, 01:17:12 PM »
I've been collecting stuff for a while trying to decide which way to go for a first time wind gen,till I came across this.
 It was going to be thrown out because no one new what to do with it.After asking Zubbly about it I decided to rescue it from total oblivion.(lol)
So here goes nothing. You know the best part about this is I'm actualy starting to grasp this stuff.(heads pretty thick)Any help or comments gladly taken,thats half the fun.
« Last Edit: February 21, 2006, 01:17:12 PM by (unknown) »
Gary D
Re: Hard to decide
« Reply #1 on: February 21, 2006, 08:41:56 AM »
If anyone wants to get a closeup shot of the last pic. it's in his files, labeled brook 9 (gives spec's ). Looks like a good project, have fun! Gary D.
« Last Edit: February 21, 2006, 08:41:56 AM by Gary D »
Dan_NS_CAN
Re: Hard to decide
« Reply #2 on: February 21, 2006, 10:57:18 AM »
Thanks Gary   I forgot to list label specs and where to find more pics.
 Brook 1.5 hp
 FL speed 1720
 208/416V
 9 leads
 Frame LS145T
 39 slots
 Having fun
« Last Edit: February 21, 2006, 10:57:18 AM by Dan_NS_CAN »
Re: Hard to decide
« Reply #3 on: February 21, 2006, 05:05:03 PM »
Hi Dan Im thinking you would have 36 slots and the voltage would be 208/230 not 416.It would be a 4pole motor for magnet placement though.What did Zubbly tell you?
« Last Edit: February 21, 2006, 05:05:03 PM by vawtman »
kitno455
Re: Hard to decide
« Reply #4 on: February 21, 2006, 06:25:05 PM »
it could be dual voltage- i have a 230/460 motor here. it has a whole bunch of leads, some of which seem to be center taps on the coils.
allan
« Last Edit: February 21, 2006, 06:25:05 PM by kitno455 »
  • Country: aq
  • Village idiot
Re: Hard to decide
« Reply #5 on: February 21, 2006, 06:36:20 PM »
Yes vawtman,
I count 36 slots 1770 means 4 pole, 208-416 means series / parallel windings for dual voltage setup This will give a lot of options between star series, star parallel delta series, delta parallel. or dare I say it,........ Jerry series/parallel. a natural for the parallel setup ...........oztules
« Last Edit: February 21, 2006, 06:36:20 PM by oztules »
Re: Hard to decide
« Reply #6 on: February 21, 2006, 06:50:54 PM »
Hi oz Ive never seen a 416v for upper voltage in U.S.Maybe im wrong but the motor is 3phase.
« Last Edit: February 21, 2006, 06:50:54 PM by vawtman »
Dan_NS_CAN
Re: Hard to decide
« Reply #7 on: February 21, 2006, 07:22:49 PM »
Hi guys:  Yes it is 36 slots, I hit the wrong key.Label says 208/416.
thanks Dan
« Last Edit: February 21, 2006, 07:22:49 PM by Dan_NS_CAN »
Geo K
Re: Hard to decide
« Reply #8 on: February 21, 2006, 10:39:32 PM »
Dan.
 I have a motor that looks just like that.It's a Alpak 230/460 volt 6 pole 1165rpm
15 HP 12 wire (delta). I put 36 (6x6) of the old #29 arched magnets in it and got
close to 10 KW out of it at 1100 rpm wired Delta.
Geo K
« Last Edit: February 21, 2006, 10:39:32 PM by Geo K »
Geo K
Re: Hard to decide
« Reply #9 on: February 21, 2006, 10:47:14 PM »
Sorry for the wrong picture
Geo K
« Last Edit: February 21, 2006, 10:47:14 PM by Geo K »
Dan_NS_CAN
Re: Hard to decide
« Reply #10 on: February 22, 2006, 07:40:37 AM »
Hi again:  There are 9 leads comming out and I'm wondering if I need to go inside to bring out more or figure a combination of the 9.Or maybe I'll work the rotor first then play with the connections after. The label for the connections is still on the motor,I think its in one of the pics.(for duall voltage). Havn't got hold of Zub again .He needed more pics of winding.Which I got up. You guys are great help.Hope someday I can figure enough of this out to help someone else and return favour.
I do have a set of TDM blades I made just for fun,they spin like crazy but havn't found a gen for them yet,I suspect I'll need a larger set for this one.(TDM only 1 meter a blade)  Thanks again
 Having fun and learning
« Last Edit: February 22, 2006, 07:40:37 AM by Dan_NS_CAN »
