Author Topic: Amp Gauge from old charger?  (Read 2271 times)
coldspot
« on: March 01, 2006, 04:44:53 PM »
HELLO_
I'm Building a control box and would like
to install an old Amp gauge. Salvaged from a dead
Battery Charger.
What I'm not sure about is wiring it up.
I need to NOT run the incoming HOT, (Pos)
straight thru it, but instead it should
be run paralell to this HOT wire using
good short wire to hook it up? (shunt?)
I just have not let any "Magic Smoke"
out of any thing in years and do not
want to let any out on this.
If anybody could PLEASE let me know
if I'm seeing the light or not.
I've been wasting all the power my mini mill
has been making on a couple of trailer
tail lights, stalling on the hook up
of the control system for fear of the magic smoke.
But am getting to many mills done and really need
to start using some of this stuff i've been
building and buying.
Amp gauge is after a heatsinked, (computer fan w/thermo sensor
extra for added cooling if getting to hot)
full wake bridge.
Another question about the bridge rec-
Running the Pos from DC PM minimill
thru the bridge on one of the AC in sides
should I also run the Neg thru this on the
other AC in side or can it just be hooked straight
to my "Pull to short" mill kill by shorting switch?
Also thinking about a "Bridge Box",
that I'll build and have each mill
run into for it's own bridge, (even if it
was bridged at mill on tower), then each
would be hooked to a bus-bar type of set-up
to combine the power before entering the
control box. This would be for my smaller
mills only, knowing that the larger ones
will need their own set-ups.
I"m also trying to figure out a way to
use the stepper micro mills combining together
for maybe a way to use this power.
A few thoughts are to series them for
lower volts with adding Amps.
Or maybe, paralell one with a mill that
dousn't get up to charging voltage in light
winds so the voltage will be there.
Any thoughts on this???
« Last Edit: March 01, 2006, 04:44:53 PM by (unknown) »
$0.02
coldspot
Re: Amp Gauge from old charger?
« Reply #1 on: March 01, 2006, 09:49:09 AM »
OOP'S
Brainfart
Micro mills
Wired paralell for adding amps
« Last Edit: March 01, 2006, 09:49:09 AM by coldspot »
$0.02
« Reply #2 on: March 01, 2006, 08:52:38 PM »
coldspot , i also have a gauge to monitor amps .
my gauge uses about 0.2 milli amps full scale.
you will need some equipment to figure out the shunt.
do you have a ammeter with a milliAmp scale?
and a voltage source?
and some resistors?
you have to figure out the resistance of your gauge , mine is 4400 ohms .
once yo have a number for the resistance it is easy to calculate the shunt needed.
but you have to know the maximum current you will be reading.?
« Last Edit: March 01, 2006, 08:52:38 PM by willib »
Kwazai
« Reply #3 on: March 02, 2006, 06:04:19 AM »
if i remember correctly an ammeter gets hooked parallel to the load..?
Mike
« Last Edit: March 02, 2006, 06:04:19 AM by Kwazai »
jimjjnn
« Reply #4 on: March 02, 2006, 06:51:33 AM »
Ammeter is connected in series. Voltmeter is parrallel.
« Last Edit: March 02, 2006, 06:51:33 AM by jimjjnn »
coldspot
« Reply #5 on: March 02, 2006, 11:14:11 AM »
willib-
THANKS !!!
Equipment-
Fluke 23, (20+ years old but, has 10Amp{Fused} & 300mA DC settings).
El-Cheap-O, "PowerProCraft" # "DT-830B", ($3.95),
10ADC unfused, & 200u, 2000u, 20m, 200m DCA settings.
Voltage source, many computer power supply's and a
old train set power supply, (12VDC)
Resistors- Lots stripped from many things.
resistance of gauge=
On Cheap-O = 00.3 @ 200 Ohm setting
Fluke 23 = 00.5 @ Ohm setting, (used same cables from cheap-O)
Fluke 23 = 01.0 @ Ohm setting using fluke cables. (super nice
push to clamp jaws, newer than unit be still old 15+ years)
 "maximum current you will be reading"
I wish I knew.
Mini Mill =
Ametek 30 with 3 blades ceiling fan blades
But do have a couple more about ready to fly
Check my Diary
Thanks willib !!!!
« Last Edit: March 02, 2006, 11:14:11 AM by coldspot »
$0.02
« Reply #6 on: March 02, 2006, 12:35:49 PM »
Did you notice the needle moving when you put the ohm meter on it?
i think you can use that as a source ,
if you can accuratly measure the current through the gauge and at the same time measure the voltage across the gauge , V/I = gauge restance.
this is what i would do , three instruments will be needed.
use one on the ohm scale to power the gauge .
use another to measure the current through the gauge
and a third to measure the voltage across the gauge..
« Last Edit: March 02, 2006, 12:35:49 PM by willib »
harrie
« Reply #7 on: March 02, 2006, 09:55:43 PM »
Hi coldspot
I also have used a ampmeter rated at 15 amps salvaged from a old battery charger, and only had to run it thru the positive wire comming from the rectifires. did not need a shunt. I think all wires comming from the geney will need to run thru the bridge.
« Last Edit: March 02, 2006, 09:55:43 PM by harrie »
coldspot
« Reply #8 on: March 02, 2006, 11:28:08 PM »
Harrie-
yea, It's a 0 15 amp range one.
So, just run the full juice thru it, (Pos side).
And hook the other side of my gen, (Neg)
to the other ,(open AC) plug on my Bridge.
I don't really thing that needs to be done.
But also it wouldn't hurt anything if done that way.
I just wanted to hook the pos from another DC PM motor/Gen
to that extra plug.
 I know I'd better not run to large a one there but
to compliment the Ametek 30 VDC, I have a
24 VDC Servo motor just about ready to fly with it.
I also have a schottky Diode in the Control box
before the Charge controller, So there wilol be
no back feed to the bridge rec on the pos side.
I have the Amp gauge wired that way but was over thinking it.
THANKS
« Last Edit: March 02, 2006, 11:28:08 PM by coldspot »
$0.02
terry5732
« Reply #9 on: March 02, 2006, 11:39:01 PM »
Usually an ameter is wired through. If you hooked it across your source it would be a short. Your 15 amp meter is only going to allow a max of 15 amps though ( or so) before the smoke. There used to be an ameter at auto parts stores that you could just set against your batt cable. The only ones I've seen lately are antiques.
« Last Edit: March 02, 2006, 11:39:01 PM by terry5732 »
coldspot
« Reply #10 on: March 03, 2006, 12:13:44 AM »
"is wired through"
Thats the question I'm asking
Wired series, Pos running thru it
with neg no were around it.
Or
Wired paralell to the Pos,
So the full power isn't running thru it.
Like a shunt.
« Last Edit: March 03, 2006, 12:13:44 AM by coldspot »
$0.02
nanotech
« Reply #11 on: March 03, 2006, 12:44:40 AM »
« Last Edit: March 03, 2006, 12:44:40 AM by nanotech »
coldspot
« Reply #12 on: March 04, 2006, 09:34:17 AM »
Thanks nanotech
Thats a good diagram of the question I asked.
« Last Edit: March 04, 2006, 09:34:17 AM by coldspot »
$0.02
