Author Topic: Coils of coller.  (Read 1128 times)
Coils of coller.
« on: April 02, 2006, 09:49:08 PM »
This should help some conversion guys see the seperation from the start windings and the run windings in this 4 pole single phase motor. The runs are the big coils.
« Last Edit: April 02, 2006, 09:49:08 PM by (unknown) »
coldspot
Re: Coils of coller.
« Reply #1 on: April 02, 2006, 05:07:30 PM »
So thats
Green= Run
Copper= Start
« Last Edit: April 02, 2006, 05:07:30 PM by coldspot »
$0.02
« Reply #2 on: April 02, 2006, 06:17:09 PM »
I can see that picture much clearer than when I look into a motor in person, and the colors help alot too.
On the 2 bottom coils I can see the green wire running from the right coil over to the left coil and over it. Those are the ones I can never find to seperate into single run coils. In that motor are the other 3 also as easy to find? Would I simply cut it to 2 equal sizes and attach leads.
Other than mine are all copper color and a blur to me, this looks simlar to some motors
I had.
« Last Edit: April 02, 2006, 06:17:09 PM by nothing to lose »
« Reply #3 on: April 03, 2006, 10:28:59 PM »
Hi NTL.
I normaly take the exsisting motor conection wires and start with one. Next I follow through the coil its conected to and on through the next coil that it connects to. Then make a cut there. 2 coils then cut.
For 12 volt use on the Garbogen it works best to wire 2 run coils in sires and then perelell them with the other 2 run coils. Do the same for the starts.
Use seperate bridges on the runs and the starts. This makes for a 2 phase PMA.
The start of the first 2 coils connects to the start of the second set of coils.
The end of the first 2 coils connects to the end of the second set of coils.
This makes the sires/perelell circut above.
« Last Edit: April 03, 2006, 10:28:59 PM by Jerry »
