Author Topic: Anemometer  (Read 1425 times)
coldspot
Anemometer
« on: June 16, 2006, 03:06:59 AM »
I'm building an  Anemometer
And I've recieved my cup n hub setup from our hosts
My bike computer info sheet
"Set-up" instructions states
that "Multiply the wheel dia in millimeters
by 3.1416 to determine the wheel factor"
I'm getting funny numbers here so bear with me
Hub dia = 1.536"
  1. 536 X 2.54 = 3.9014
  2. 9014 X 10 = 39.0144
  3. 0144 X 3.1416 = 122.5676
In the sheet they have numbers that are four digets long
AKA: 1596, 2124, 2237 ,(20", 26.6" 28")
Has anybody else done one of these?
« Last Edit: June 16, 2006, 03:06:59 AM by (unknown) »
$0.02
Re: Anemometer
« Reply #1 on: June 15, 2006, 09:32:18 PM »
what happens when you plug in your number?
i get 124 , but i rounded 1mm to 0.039 "
« Last Edit: June 15, 2006, 09:32:18 PM by willib »
Re: Anemometer
« Reply #2 on: June 16, 2006, 07:00:34 AM »
  Yep 124 is close enough...
« Last Edit: June 16, 2006, 07:00:34 AM by Norm »
coldspot
Re: Anemometer
« Reply #3 on: June 25, 2006, 07:24:35 PM »
I've put 123 in the bike computer
So far nothing
kind of like putting up a mill
Not enough wind to test yet
might have to take it for a ride
Did extend the wire, used a 25' phone cord and a phone
cord coupler. Only used the red n black wires, saved the
yellow n green for maybe something else, (was thinking power to the computer
till I realized it would be down n easy to add power to. LOL)
Found a old computer part with bearing that press fit inside of the hub, had to switch around the cups because it would un-screw the mounting screw and fall down, lol. :(
Now it should just tighten it up.
Pictures to be posted l8r
« Last Edit: June 25, 2006, 07:24:35 PM by coldspot »
$0.02
coldspot
Re: Anemometer
« Reply #4 on: June 26, 2006, 08:14:46 PM »
O-
I've been BAD !!!
I re-read the otherpower
"An Easier Homemade Anemometer
Built using a digital bicycle speedometer"
And found out about the calibration-
They didn't just do the math like I did and wonder why?
They started with a much larger number for the wheel size
Mine has yet to show more than a mile per hour wind speed.
I used
Hub dia. = 1.536"
X 2.54 = 3.9014
X 10 = 39.0144
X 3.1416 = 122.5676.
Rounded up to 123
Darn small wheel size
They used 1320
And test with moving car from there. LOL
I'll post more after more testing
l8r
« Last Edit: June 26, 2006, 08:14:46 PM by coldspot »
$0.02
