Author Topic: Permanent Magnet DC Motor Windmill  (Read 1571 times)
Devo
« on: August 03, 2006, 02:32:36 AM »
This is a 1/2 HP DC permanent magnet motor with a set of Art's Blades on it.It is on a 30 foot silo & the blade flew off in a windstorm the other night & landed on a steel roof 20 feet below without breaking. Wow they are stronger than they look !!
I have seen 7 amps at 13 volts , usually between 1 & 4.5 though.
I had both these tied in today with this one for the first time
Needle spent a fair bit of time past 30 amps today , finally -woohoo.
Now for a decent tower...
Devo
« Last Edit: August 03, 2006, 02:32:36 AM by (unknown) »
Devo
Re: Permanent Magnet DC Motor Windmill
« Reply #1 on: August 02, 2006, 08:36:03 PM »
I apologize for the picture size , I thought I resized them , not sure why they came out so big. I can resize them but I can't edit it out.
Sorry Admin....
Devo
« Last Edit: August 02, 2006, 08:36:03 PM by Devo »
« Reply #2 on: August 03, 2006, 12:57:23 AM »
hi devo
looks great !
the first one is about 400K
if you resize it just rename the new one
that should do it ..
glad to hear about your good amps
« Last Edit: August 03, 2006, 12:57:23 AM by willib »
RayW
« Reply #3 on: August 03, 2006, 07:55:12 AM »
What part of the blade failed to
cause it to fly off?
Details please.
    RayW
« Last Edit: August 03, 2006, 07:55:12 AM by RayW »
Devo
« Reply #4 on: August 03, 2006, 03:20:38 PM »
100 kmh winds on a windmill with no furling & no Key in the key slot just a grub screw. It started slipping on the shaft & wore the 5/8" shaft down to about 1/2 inch. I have a few of these motors around so I put up another & used key stock in the key slot...
The blades actually struck the tower under the high winds & flew off but still remained usable.
Devo
« Last Edit: August 03, 2006, 03:20:38 PM by Devo »
Devo
« Reply #5 on: August 03, 2006, 03:38:06 PM »
I tryed to resize again , when I click on the pkoto in my photo uploads they both look a normal size but in the post they are huge...
Not sure what I am doing wrong?
Devo
« Last Edit: August 03, 2006, 03:38:06 PM by Devo »
« Reply #6 on: August 03, 2006, 03:44:18 PM »
They look fine here.
And the 'size' is good too. 45K and 25K.
There is something about 80% of the screen width... whatever... but they look the same 'inches' as most from this end.
« Last Edit: August 03, 2006, 03:44:18 PM by ghurd »
« Reply #7 on: August 03, 2006, 04:32:32 PM »
looks fine here--well under the 100k limit..
45 and 25......if you have win98 just right click on the picture and it will
show what size it is........[properties]
« Last Edit: August 03, 2006, 04:32:32 PM by hiker »
coldspot
« Reply #8 on: August 03, 2006, 07:28:07 PM »
What can you tell us about these
"Arts" blades?
Length?
Mounting style?
Price?
How long you have flown them?
Are you happy with them?
« Last Edit: August 03, 2006, 07:28:07 PM by coldspot »
$0.02
« Reply #9 on: August 04, 2006, 01:20:08 AM »
I had a similar problem. When I resized and called it the same name it was still huge. Later when I looked it had changed size.
Maybe you need to try refresh after doing a change, I shall try that next time.
Your pictures are fine now.
« Last Edit: August 04, 2006, 01:20:08 AM by Flux »
Devo
« Reply #10 on: August 04, 2006, 06:19:58 AM »
The pictures looks fine here today too.
The blades have an aproximate 8 foot diameter when assembled. They are much lighter than the wood ones I have carved & come with a hub that has a 4 bolt pattern or with individual ends you can mount to a steel disc.
I am happy with them so far , only had them for a week.
The only 2 things that caught my attention was the root is very narrow so they don't start quite as easy as the wooden ones & they are very flexable so you need good good tower clearance.
They are quite strong & for me much better then carving as my time is limited & they are reasonably priced. I will probably try a few more down the road , I want to try a set of Jerry's now.
I think I have 7 of these dc motors kicking around to put up on small towers
Devo
« Last Edit: August 04, 2006, 06:19:58 AM by Devo »
Devo
« Reply #11 on: August 04, 2006, 06:28:54 AM »
Coldspot here is Art's E-mail  elsieart@ozarkmountains.com
« Last Edit: August 04, 2006, 06:28:54 AM by Devo »
coldspot
« Reply #12 on: August 04, 2006, 04:41:13 PM »
Devo-
THANKS!!!!!!
Are they a three blade set?
4 bolt on the hub?
So it's a hub plate that needs to be bolted to
another plate?
Please take a close up of the hub n blades if you get
a chance.
« Last Edit: August 04, 2006, 04:41:13 PM by coldspot »
$0.02
