Author Topic: configuration experiments  (Read 1094 times)
spinner
« on: August 04, 2006, 05:57:22 PM »
I just uploaded the results of a recent experiment...I hope you find it of interest; it is listed as "an experiment in my files should you care to look it up...it was done using my stator-x which I finally got to work
thanx, spinner
« Last Edit: August 04, 2006, 05:57:22 PM by (unknown) »
Re: configuration experiments
« Reply #1 on: August 04, 2006, 05:36:39 PM »
i have all six leads coming out of my alt--in star it loads up the alt bad--fighting all that wire--prop slows way down......
when wired in jerry delta--prop spins a lot faster and almost three times the amps..
sure it dosent have the high volts as in star [drill test]..
but being that it spins over easyer when wired in jerry delta i reach cut in speed in a lower wind then when wired in star..just my real life tests..
--the alt is a 9 and 12 setup--120 winding per coil--neo and ceramic powered..
« Last Edit: August 04, 2006, 05:36:39 PM by hiker »
« Reply #2 on: August 04, 2006, 09:04:13 PM »
Spectacular view you have there hiker !
« Last Edit: August 04, 2006, 09:04:13 PM by willib »
« Reply #3 on: August 05, 2006, 03:23:01 AM »
thanks willib..
thats a test i did in the spring--i rebuilt the mill sence then--smaller and stronger.
and just a comment on star--on my little mill [8" rotors] i need all the amps i can get
so thats why i wired in jerry delta plus i needed a lot of winds per coil for volts..
of course on the bigger mills i could see star working fine--they don"t need a whole lot of winds per coil--therefore they don't have a whole lot of wire to fight..
just my way of thought...i just finished a smaller mill a while back-8and6-7.1/4" rotors.. saw blades-90 turns per coil-#17 wire-cut in speed is a bit high -but it still works great-no furl -small blades-and that is wired in star for volts-needed star because of the high cut in speed..
heres a shot of the rebuilt mill...
« Last Edit: August 05, 2006, 03:23:01 AM by hiker »
« Reply #4 on: August 05, 2006, 06:55:12 AM »
  Hiker, Like the way you get such good results
from such simple looking machines....I'll bet
you're an inspiration to a lot of newcomers !
  Does this one have any twist at all to the
blades ?
               ( :>) Norm.
« Last Edit: August 05, 2006, 06:55:12 AM by Norm »
« Reply #5 on: August 05, 2006, 07:29:32 AM »
  Thanks for sharing your results...someday I'd
to make a machine pedalpower direct drive where
about 90 rpm would be enough to charge a battery
so any data is helpful....notice I said Someday ?
                ( :>) Norm.
« Last Edit: August 05, 2006, 07:29:32 AM by Norm »
« Reply #6 on: August 05, 2006, 03:33:47 PM »
hey norm..
 sence the angle is in the hub--i took a wood rasp to the front of the blades[less then 3/4 of the way up on the blade] on the leading edge- to slowly flaten out to the end of the blades..and of course i had to make a bunch of stop cuts on the back side to make the airfoil..saved a lot of work by having the angle in the hub....don't ask me the tsr.  im not into numbers..just carve out what looks like a good blade--then balance everything out--and let er fly.....
heres a side view...
sorry spinner did'nt mean to run wild with your post.....
« Last Edit: August 05, 2006, 03:33:47 PM by hiker »
« Reply #7 on: August 05, 2006, 09:11:33 PM »
   thanks Hiker my apologies too spinner....
  Wood rasp huh? Yep they can really chew up some wood
alright...I like to use a wood plane pulling toward you like a draw knife as long as you don't
go against the grain...
  I was thinking that maybe someday I could
make something like yours on a smaller scale
that would work on a couple of those little
stepper motors that Ghurd gave me he says that
pvc blades will work in those 5mph breezes we
have here in NE Ohio but I think wood will
work better in my opinion plastic blades really
spin fast until you put a load on them...
then they seem to just fizzle out...
               ( :>) Norm.
« Last Edit: August 05, 2006, 09:11:33 PM by Norm »
spinner
« Reply #8 on: August 06, 2006, 07:16:17 AM »
HiYa Wild,
got a schematic of the jerry/delta that ya can post...i seem to have mislaid mine 'mongst all the junk in my  lil workshop (memory seems to serve me poorly 'cause i don't seem to see the results i should be getting with it)
iwould like to include a series of experiments with it as part of my stator-x project
thanx
spinner
« Last Edit: August 06, 2006, 07:16:17 AM by spinner »
