Initially the current into the 6.3 Volt battery was 90mA after three minutes it was 30mA and after 10 minutes it was 20mA
from left to right the meters are voltage , current ,voltage , current
the left two are voltage and current solely from the charged cap , the right two are the boosted voltage and boosted current.
input ::::::::::::: output
2.4V at 310mA and 6.3V at 90mA ; initial
2.19V at 120mA and 6.3V at 30mA ;after three minutes
1.73V at 70 mA and 6.3V at 20mA ; after ten minutes
the caps we are thinking of getting are the same voltage but are 350 Farads this one is just 110 Farads.
but it gives you an idea of what they are capable of, i hope.
capacitance in series add like resistors in parallel
two in series of the 350F variety can handle 5V and the total capacitance will be 175F
7 in series can safely handle 17.5 Volts and the capacitance will be 50 Farads , not too shabby
i know the caps can be damaged by overvoltage , thats what i hear .
on the Maxwell site they have a passive scheme , using resistors to balance the voltage on each cap in the string.
i dont think that i've ever had mine over 2.7 volts and it still seems to work fine,
My cap cost $31.20 less tax and shipping i'm not about to test how much overvoltage it will take before it doesn't work .
just a word of caution , i paid close attention to the cap voltage when charging it up.
i would spin the alt, while watching the voltmeter , stop it , see what it was up to , it would take several minutes and a lot of effort to charge by hand.
i've found that when i get close to 2.5V , i go over to say 2.6V stop and see where it ends at...
unlike a battery when you stop charging it, thats where it is , the voltage doesn't go down , without a load , on it.
