Author Topic: Torque on a stator  (Read 1234 times)
Torque on a stator
« on: April 10, 2007, 03:56:35 PM »
 48 neos , 24 per rotor ,1 inch long by 7/8 inch dia N40 , 18 coils , when done,
I was charging a 6V battery and measuring torque on the stator
this is the data i collected:
 9 Newtons at 6 inches
 160 RPM
and into the 6V battery was
 8.9V at 1.4A
this is the alt i used , before i put half the coils on
so i have 9 coils , from previous experiments ,installed similar to the mini GenII
Although not optimal .. but needed to charge batteries and keep my excercizing going since i took the mini gen II off of the excercize bike
the stator holder is able to rotate about the central axis quite freely.
so i was able to attach a 0- 20 newton spring scale at a distance of 6 inches from the central axis
i am trying to calculate the power output / power input ...efficiency
i'm sure i could figure it out ? , but if anyone has the formula in the front of their thoughts i would really appreciate it
« Last Edit: April 10, 2007, 03:56:35 PM by (unknown) »
Re: Torque on a stator
« Reply #1 on: April 10, 2007, 10:19:34 AM »
22.7W in, 12.5W out 55%
« Last Edit: April 10, 2007, 10:19:34 AM by Flux »
« Reply #2 on: April 10, 2007, 10:28:10 AM »
Thanks Flux, but how did you arrive at that ?
« Last Edit: April 10, 2007, 10:28:10 AM by willib »
« Reply #3 on: April 10, 2007, 10:52:19 AM »
willib;
Not to speak for flux but thats an easy one as far as math goes..
take the # you have divide it by the value you "should" have at 100% take the number from that times 100 it gives percent out.
« Last Edit: April 10, 2007, 10:52:19 AM by TomW »
« Reply #4 on: April 10, 2007, 10:52:31 AM »
The long way round.
9N is 9/9.81 x 2.2 lbs. and at 6" radius gives a torque of 1lb ft.
HP is 2pi x speed x torque/33000. Watts = HP x 746
With your force in N it may have been easier to convert the radius to M and work in metric. This would have got the answer directly in Watts with the speed in rps.
1M is about 39.4" so 6" 6/39.4M   160 rpm =160/60 rps.
Power = 2pi x 9 x (6/39.4) x 160/60
22.9W
« Last Edit: April 10, 2007, 10:52:31 AM by Flux »
« Reply #5 on: April 10, 2007, 02:23:07 PM »
Thanks Flux thats what i was looking for..
i would include a picture , but it does not look presentable at the moment , none of the coils are soldered together or otherwise connected properly..
i just have aligator clips making the connections , but it is cool when it starts to charge, the stator holder and stator rotate in the direction of rotation and puts a pulling force on the spring scale.
the angle that the spring scale at, is not quite tangent to the direction of rotation
i think that matters a little ?
i havnt done any calculatons yet but i will ,
 this is the approximate angle
« Last Edit: April 10, 2007, 02:23:07 PM by willib »
