Hi there
Thanks for the comments.
The coils are the right size 25 turns of 1.8mm 2 in hand,I think it the way the picture is taken(photography is'nt my strong point.they are pretty tight when cast.
The blades are another matter,I am VERY WORRIED about them,I built then from the dimensions given on Hughs book they are 22mm(Just under 1 inch) thick at the tip and are 50mm(2 inches)at the root.
I took some more pictures that might help.
The wood beside the blade is 50mm(2 inches thick),And is the thickness at the root.
Agian the wood the blade is sitting on is 50mm(2 inches) thick.
DOES THIS LOOK RIGHT NOW??
Or did i Make a mess of things? :-(
Or should i keep away from cameras :-).
Thanks again
Im Very Very Greatful for all the comments GOOD or BAD
