Author Topic: rewired car alt..  (Read 953 times)
rewired car alt..
« on: September 05, 2007, 10:48:09 AM »
heres the origanal windings[one phase][wave]
new windings[wave]
now the cut in speed is a lot lower[dont have to pedal as fast]..
and the power out put is more in line with a pedgen..[with a lower speed as well]
im still testing it out[field load]more later......
i have a 4hp ac motor 24 slots--wave winding should work on it as well..
any one try wave winding on a motor conversion????????
« Last Edit: September 05, 2007, 10:48:09 AM by (unknown) »
rippersoftware
Re: rewired car alt..
« Reply #1 on: September 05, 2007, 08:42:07 AM »
Very nice!  Looks professional.  I notice that the wire is colored.  What did you use for wiring?  How many magnets is on your rotor?
Thanks.
RipperSoftware
« Last Edit: September 05, 2007, 08:42:07 AM by rippersoftware »
« Reply #2 on: September 05, 2007, 02:54:41 PM »
thats a stock rotor-electric mag.--no batt. was used at any time..
this started out as expermint seeing what i could get out of a stock car alt..
check my diarys-[pedgens]
but i went ahead and rewired --just to see what diffrance that would make..
-results were easyer cut in speed--and a slower rate of pedalling at a workin rate.
i had to use a 30watt. bulb on the field for this,only had to use a taillight bulb on stock alt.[ the bulbs are used as a simple regulator]
ALL in ALL--it would be easyer just to use a tread mill motor[or others] for a pedgen..
its kind of a hassle to hook up all the extras[solinode-right bulb size] just to get the same amount of power output at the same load and pedal rate..
the stock car alt CAN put out a ton of power--its all up to how hard you can pedal.
  thats plastic coated insulated wire i used-just what i had laying around..
  worked out fine for a human powered alt-theres now way i could have gotten the FULL power out of the big wire they use in stock alts[not on a pedgen]...
well thats about it for car alts --think its time to move on........................?
« Last Edit: September 05, 2007, 02:54:41 PM by hiker »
