Author Topic: Desulfator  (Read 4279 times)
eleventhree
Desulfator
« on: September 17, 2007, 10:21:12 AM »
Desulfator
I found this desulfator circuit in a link on this thread:
here.
Circuit courtesy of Ron Ingraham
i live in new zealand and im currently sourcing parts.
Transistors:
Q1 IRFZ44V - RS # 2509055009
Q2 2N2907  - Jaycar # ZT2322
Capacitors:
C1 100uF 25V Low ESR - Jaycar # RE6322
C2 47pF (0.047uF) Ceramic - Jaycar # RC5320
C3 4.7pF (0.0047uF) Ceramic - Jaycar # RC5308
C4 100uF 25V Low ESR - Jaycar # RE6322
C5 10pF (0.01uF) Ceramic - Jaycar # RC5312
Diodes:
D1 1N4744
D2 FR602
D3 1N4148
D4 1N4148
IC's:
NE555 - Jaycar # ZL3555
Inductors:
L1 1000uH
L2 200uH
Resistors:
R1 100Ω
R2 15KΩ
R3 100Ω
R4 270KΩ
R5 15KΩ
« Last Edit: September 17, 2007, 10:21:12 AM by (unknown) »
eleventhree
Re: Desulfator
« Reply #1 on: September 17, 2007, 04:50:06 AM »
Finnished sourcing diodes. Im not sure about editing Diary Entries yet.
Diodes:
D1 1N4744 - Jaycar # ZR1415
D2 FR602 - RS # 485-4334
D3 1N4148 - Jaycar # ZR1100
D4 1N4148 - Jaycar # ZR1100
« Last Edit: September 17, 2007, 04:50:06 AM by eleventhree »
Re: Desulfator
« Reply #2 on: September 17, 2007, 06:01:21 AM »
11-3;
Sadly, you can't.
« Last Edit: September 17, 2007, 06:01:21 AM by TomW »
Re: Desulfator
« Reply #3 on: September 17, 2007, 08:08:24 AM »
That looks like a good circuit I've never built this one but will do so . The  circuit linked below can be scaled to a small amorphus solar setup and works well to clean them up and put a good charge on them .
It's the rest of the thread Jerry's Charger
http://www.otherpower.com/images/scimages/48/Jerry_charger.jpg
  The circuit your building samples the battery voltage hits the coils at what appears to be highfrequency with good potential you'll need solid connections , and a scope would be good .
 Jerry's circuit uses the 555 at a 1 second rate and dumps a large cap . The battery impeadance is easy to watch .
« Last Edit: September 17, 2007, 08:08:24 AM by tecker »
eleventhree
Re: Desulfator
« Reply #4 on: September 18, 2007, 01:12:33 AM »
thanks for your comments. i will look into building jerry's version when i have completed this one.
« Last Edit: September 18, 2007, 01:12:33 AM by eleventhree »
