Author Topic: This summer progress.  (Read 1505 times)
margusten
« on: September 19, 2007, 01:36:23 PM »
No time for long story, mainly pictures.
Biggest performance was 9m tower - actually planned 17m.
You can see 9m tower testing 2m and 3m scrap blades. 2m blades from plywood at 10 degree are heavy and spinning slowly. Blades from 160mm PVC tube are much better but weak for 3m diametre mill.
Test stator to find out how many turns I really need:
2 Rotors using 2*24 big hard drive magnets. Check my previous postings.
Wiew from backside. No furling system. It has to be strong enough.
A tail made from microwave case (actually 2 big cases).
Military wintch for future use.
New homemade controller using old computer PS case. Power resistors inside and fan turns on automattically when battery voltage is 14,5V.(blue led turns on)
Green led indicates that windmill is working.
Smaller windmill(working more than 1Year now) has old controller.
1.6m diametre 2blades and wery fast, I've seen 2000 rpm in good winds and sound like airplane. Below 1000 rpm allmost silent.
Wind speed measured by homemade anemometer based on bicycle computer.
Next time more intresting things.
Margus
« Last Edit: September 19, 2007, 01:36:23 PM by (unknown) »
Janne
  • Country: fi
  • Turbiini
    • My image gallery
Re: This summer progress.
« Reply #1 on: September 19, 2007, 10:04:50 AM »
looks nice.. i like the bicycle computer anemometer idea. are those brake disks from a volvo? (just guessing from the bolt pattern :)
« Last Edit: September 19, 2007, 10:04:50 AM by Janne »
« Reply #2 on: September 19, 2007, 04:22:58 PM »
nice mill..
what kind of a hard drive did those big mags come from?????????
« Last Edit: September 19, 2007, 04:22:58 PM by hiker »
chadking
« Reply #3 on: September 19, 2007, 09:43:43 PM »
Looks like a productive summer!  Yous eem to be pretty handy at recycling things for new uses. Keep us updated with new projects.
« Last Edit: September 19, 2007, 09:43:43 PM by chadking »
margusten
« Reply #4 on: September 19, 2007, 11:56:38 PM »
OK, one more picture how to make exactly identical 2 magnet discs:
These big magnets came from old SCSI hard drives, I believe from server. I bought 16 of them.
MADE IN USA written on them.
Real heavy and double height of standard 3,5" hard disk.
Margus
« Last Edit: September 19, 2007, 11:56:38 PM by margusten »
« Reply #5 on: September 20, 2007, 01:18:32 AM »
Nice work, you seem able to build things well so I can't understand why you insist on building things without furling.
2000 rpm at 6ft diameter is definitely up into the aeroplane noise region and must be testing your props to the limit. With your small magnets then it is in a runaway condition and life is a bit frantic.
« Last Edit: September 20, 2007, 01:18:32 AM by Flux »
