Author Topic: Things I've been up to lately  (Read 3585 times)
Devo
« on: October 04, 2007, 08:10:02 PM »
I had an old 4 pole 5/8hp induction motor I had put 4 #29 curved neo's in a while back. I finally took it apart & did my first rewind ,of course if not for ready Zubbly's posts last year I would not have a clue.
Hears the rewind it's a 36 slot motor I went with 3 phase 6 pole -22 windings of #17 wire per coil.
The stator
The rotor
I had 6 foot blades that fell off a table last year , I will convert it to a 2 blader....
Also working on a 40 to 45 foot tower(Finally....)
Here is my old 11 foot dual rotor apart after over a year
based mainly on hugh's plans(thank you sir)
I had 1 burnt coil but I knew I had exceeded the limits a few times(unit still worked though..
This was the school project I did last year, it sat in front of a big industrial fan & had a 12 volt drill battery inside when the fan turned the "baby mill" the volt meter would go up, on the back there was a cooling fan that when turned on would show the change in the amps going into the battery with a small digital amp meter
Here is the start of a new dual rotor for my 11 footer, I am also thinking of trying one with the same round magnets dan is using know as I already have the steel plates & the stator mould
Hope everyone is having fun with wind. Should I be deleting old pictures out of my files once in a while? is there a limit?
Does this site except donations like others? I never see a thread for it...
Have fun all,I'll post the results of the reound 5/8 hp soon
Devin
« Last Edit: October 04, 2007, 08:10:02 PM by (unknown) »
Re: Things I've been up to lately
« Reply #1 on: October 04, 2007, 05:52:27 PM »
Hi Devo
 Did you try spinning the conversion yet?
« Last Edit: October 04, 2007, 05:52:27 PM by vawtman »
Devo
« Reply #2 on: October 04, 2007, 06:02:15 PM »
I just came in from the shed from doing this on the drill press, I started a new diary on the conversion-it spins easier with the 6 mags by hand then the 4, not a lot but a little easier.
Devin
« Last Edit: October 04, 2007, 06:02:15 PM by Devo »
« Reply #3 on: October 04, 2007, 06:21:36 PM »
Devin
 The slightest cogging can really hinder the startup of a turbine has you probably know.
« Last Edit: October 04, 2007, 06:21:36 PM by vawtman »
Nothing40
« Reply #4 on: October 04, 2007, 06:38:18 PM »
Wow,A radioactive rotor!
How many Megawatts are you expecting?  ;-)
« Last Edit: October 04, 2007, 06:38:18 PM by Nothing40 »
Devo
Radio active rotor
« Reply #5 on: October 04, 2007, 07:23:59 PM »
LOL-  yeh the Flash on the camera really changed the colour of green. Maybe that will give it some extra juice..
The cogging should be ok , I had a 6 foot prop on it before & it started ok & it seems a little easier now.
I will try to get the prop on & get it on a test tower or the silo soon
Devin
« Last Edit: October 04, 2007, 07:23:59 PM by Devo »
