Author Topic: Building a better human powered battery charger  (Read 1698 times)
« on: December 30, 2007, 08:26:44 PM »
   The exercise bike has a 20 inch bike wheel
the original tire was a solid sponge rubber, not
very good for a friction driven generator to be
running against, luckily a regular bike tire and
tube fit on it, had to drill a hole in the rim
for the tube stem...minor detail.
  I made an 1 1/2 wood pulley for the little
generator, so everthing considered I calculate
that if I pedal at a 60 rpm rate, the wheel spins
at 120. This would be about 7mph and the generator is spinning about 1920rpm (crank to
generator ratio 1:32)
   This seems to be very inefficient....I'm
putting about 800Ma into 6 700Ma AA batteries
at about 9.5 v0lts or about 7 watts.
  I'm handcranking this and exerting as much
energy as I was in physical therapy at 50 watts
according to the meter on their machine.
  I figure that if I hooked a 30 volt Ametek to
the wheel with a 3 inch dia. pulley then pedaling
at a 7mph rate...60 rpm the Ametek will be spinning about 1000 rpm and I'll be charging a
12 volt battery at least 30 watts??
  Is my math about right? ....over or underestimating ?
  What is the best operating range for a 30 volt
Ametek?
« Last Edit: December 30, 2007, 08:26:44 PM by (unknown) »
Boss
  • http://outfitnm.com
Re: Building a better human powered battery charge
« Reply #1 on: December 30, 2007, 07:36:06 PM »
I am interested in this project as I too built an exercise bike with an alternator.
The system I built was more for exercise than electrical output.
I haven't been able to measure the output, because my alternator is an automotive type and it uses much of the energy of pedaling to energize the alternators field coils and I only have a direct connection amp meter.
I knew the power output is low, but from your numbers I can see that it is very low.I am thinking of building a little axial flux alternator for it, but if I can't substantially increase the output I may just leave it as it is.
« Last Edit: December 30, 2007, 07:36:06 PM by Boss »
Brian Rodgers
« Reply #2 on: December 30, 2007, 10:06:59 PM »
It looks like at about 400 rpm the Ametek will
produce about 64watts...may even have to make
the pulley larger to slow it down to where it
won't be so hard to pedal.
Should have some results in a couple of days
soon as I get New Year out of the way.
......Happy New Year BTW to you and whoever is
reading this post!
« Last Edit: December 30, 2007, 10:06:59 PM by Norm »
