I'm faced with an electronics problem that has little to do with RE, but I'm sure that the knowledge is on this board so I will ask it here anyway. Well, technically, it -may- be a little RE related as the finished tool will be used to spotweld battery tabs to NiCd & NiMH batteries...
It's a capacitor discharge spotwelder. For those who don't know what it is, these links explain best:
http://www.philpem.me.uk/elec/welder/
http://www.philpem.me.uk/elec/welder/images/schematic.png
http://sunstoneengineering.com/site/pages/products (these products make me drool)
My design is mostly based on the schematic as found in the first link, with some modifications. First of all, it uses more capacity, about 2 F at 25 V (30 pcs of 68.000 uF/25 V elcos, total ~600 Ws). I have modified the trigger by adding a NE555 to debounce the switch and to make sure that continuous pressing of the trigger gives just one (~ .5 s) fired pulse to the thyristor. The .5 s time is pretty long (the thyristor will discharge the capacitor in milliseconds, if not microseconds) to make sure that the relay will properly disconnect the PSU as otherwise the thyristor (SCR) would remain conductive due to the large supply current (~13 A) of the PSU.
(hi-res schematic can be found here: http://www.anotherpower.com/gallery/dinges/spotwelder_2?full=1)
The thyristor that I intend to use is a large beefy P202CH12, rated at 325 A continuous and 3500 A pk. It should be more than fine for this application. However, the thing that I can't figure out is how to properly drive the gate.
In the datasheet (http://www.westcode.com/p0327wc.pdf (warning, it's an 8 MB .pdf file)) on page 3 it says, under item nr. 4 'gate drive': 'the recommended gate drive is 20 V, 20 ohm'. Sounds pretty straightforward. But, when I look at the graph on page 7, 20 V at 1 A seems to lie way outside the maximum-rated boundaries. Also, on page 2, it says that maximum forward peak gate voltage is 12 V. Obviously I'm missing something here... but what... ?
To the point, the questions I have:
- using 12V, what resistor value R would you recommend so that the thyristors turns fully on in the shortest amount of time, yet doesn't exceed its maximum ratings ?
- would a snubber network over the K-A be needed for this application ? The datasheet recommends 22 ohm & .22 uF but I don't think one would be needed in this application. But I may be wrong.
Any advice from those having experience driving thyristors will be greatly appreciated.
Peter.
