Author Topic: Wind  (Read 933 times)
bj
Wind
« on: February 10, 2008, 06:17:12 PM »
     The turbine itself is a set of those composit blades.  Six blades,
five foot diameter.
     The alternator started as a GM truck unit, I believe orignally
120 amp.  I installed a big Neo ring instead of the wound rotor,
and rewound the stator.  If memory serves, 19 wraps of #16 per coil.
That's all I could fit in.  At a measured 300 r.p.m. it puts out 35.5
volts, open circuit.  At the moment it is hooked up to four D8D
batteries--at 24 volts.  I have seen surges to 50 amps on really
windy days--like yesterday.  At the moment there is no furling mechanism
although when the snow goes I'd like to change that.  In really big
winds, it's a bit frightening.
     bj
« Last Edit: February 10, 2008, 06:17:12 PM by (unknown) »
bj
Lamont AB Can.
Re: Wind
« Reply #1 on: February 10, 2008, 11:24:51 AM »
bj;
You might consider giving each Diary you submit a unique name. That would make it easier to distinguish them.
Just a thought.
« Last Edit: February 10, 2008, 11:24:51 AM by TomW »
bj
Re: Wind
« Reply #2 on: February 10, 2008, 01:45:16 PM »
   Will do in the future
    bj
« Last Edit: February 10, 2008, 01:45:16 PM by bj »
bj
Lamont AB Can.
Re: Wind
« Reply #3 on: February 10, 2008, 06:51:14 PM »
Don't let that distract you from posting as much as you've been doing.  You have a lot of great flow going in your diaries.  Thanks for airing your thoughts out loud.
« Last Edit: February 10, 2008, 06:51:14 PM by MattM »
Warrior
  • Country: ar
Re: Wind
« Reply #4 on: February 11, 2008, 03:24:12 AM »
Hi BJ, interesting post. Pictures?
Thanks,
« Last Edit: February 11, 2008, 03:24:12 AM by Warrior »
