Author Topic: Rewind finished  (Read 4057 times)
fungus
Rewind finished
« on: February 29, 2008, 02:07:26 PM »
Just finished the rewind , didnt quite have enough wire so soldered/heatshrinked some more on for the last 30 turns of the last coil .. they did start to get hard to insert with the last few coils :)
Next step will be to soak it all with epoxy etc , I've ordered some off ebay ..
Will get pictures soon ..
« Last Edit: February 29, 2008, 02:07:26 PM by (unknown) »
fungus
Re: Rewind finished
« Reply #1 on: February 29, 2008, 07:20:36 AM »
I'll do these as a before/after ..
« Last Edit: February 29, 2008, 07:20:36 AM by fungus »
Re: Rewind finished
« Reply #2 on: February 29, 2008, 07:23:36 AM »
Well done.
« Last Edit: February 29, 2008, 07:23:36 AM by Flux »
MattM
Re: Rewind finished
« Reply #3 on: February 29, 2008, 07:40:17 AM »
How did you unwind the old wire out of the stator?  Always seems like the wires are epoxied in these motors.
« Last Edit: February 29, 2008, 07:40:17 AM by MattM »
fungus
Re: Rewind finished
« Reply #4 on: February 29, 2008, 07:48:37 AM »
I just clipped it out, but making sure I was able to keep track of the connections/slots ..
Tested it on a 12v battery as a motor and it runs nice and smooth, slow , my tachometer says 100rpm but its not too reliable.
« Last Edit: February 29, 2008, 07:48:37 AM by fungus »
Re: Rewind finished
« Reply #5 on: February 29, 2008, 08:13:39 AM »
Amazing!
People who have not tried it won't understand.
« Last Edit: February 29, 2008, 08:13:39 AM by ghurd »
Re: Rewind finished
« Reply #6 on: February 29, 2008, 08:16:43 AM »
a feather in your cap fungus.
are you going to go with ed's lenz2 ?
« Last Edit: February 29, 2008, 08:16:43 AM by electrondady1 »
fungus
Re: Rewind finished
« Reply #7 on: February 29, 2008, 08:20:58 AM »
Yep, I think I'll try a 2*3 lenz first , 2' dia , 3' tall , should work out nice ..
I still have the arbour and hub from when I was using it as a hawt so it shouldnt be too hard.
« Last Edit: February 29, 2008, 08:20:58 AM by fungus »
Re: Rewind finished
« Reply #8 on: February 29, 2008, 09:02:42 AM »
Fungus;
Pretty nice work.
Glad to see at least a few folks on here that can do something besides bang on a keyboard professing how much they know.
Well done.
Keep us posted.
« Last Edit: February 29, 2008, 09:02:42 AM by TomW »
blueyonder
Re: Rewind finished
« Reply #9 on: February 29, 2008, 11:50:13 AM »
 well done lad.
   its good you posted the pics now i can understand just how much work you done .
   and how it was done.
« Last Edit: February 29, 2008, 11:50:13 AM by blueyonder »
gotwind2
  • ben[at]gotwind.org
Re: Rewind finished
« Reply #10 on: February 29, 2008, 12:22:55 PM »
Nice work Fungus.
You must have the patience of a saint, winding and counting all those winds.
I look forward to see the next stage of your VAWT project - maybe prove the VAWT doubters wrong??
Keep it up.
Ben.
« Last Edit: February 29, 2008, 12:22:55 PM by gotwind2 »
Re: Rewind finished
« Reply #11 on: February 29, 2008, 01:13:31 PM »
Tried rewinding a couple of small motors...can
appreciate the labor involved...but of course
if it's fun...it's not work !
Nice Job !
« Last Edit: February 29, 2008, 01:13:31 PM by Norm »
Re: Rewind finished
« Reply #12 on: February 29, 2008, 01:31:52 PM »
keeping my fingers crossed.
volvo farmers 100usd. = 50 lbs. sterling?
« Last Edit: February 29, 2008, 01:31:52 PM by electrondady1 »
Re: Rewind finished
« Reply #13 on: February 29, 2008, 02:33:59 PM »
Oh yes, please do that!
Then come and finish off my stalled VAWT project!  B^>
« Last Edit: February 29, 2008, 02:33:59 PM by DamonHD »
  • Country: aq
  • Village idiot
Re: Rewind finished
« Reply #14 on: February 29, 2008, 03:58:01 PM »
Excellent work there Fungus.
You have crossed a barrier I didn't cross until I had 30 years more water under the bridge than yourself.
It requires patience and grit to see it all the way through and you have displayed both at a tender age.
I think you should bask in the satisfaction that you have achieved something not a lot of people have accomplished.
Well done.
.........oztules
« Last Edit: February 29, 2008, 03:58:01 PM by oztules »
sPuDd
Re: Rewind finished
« Reply #15 on: February 29, 2008, 09:40:56 PM »
Well done Fungus,
   I tried a rewind on a 250W 3ph AC motor and gave up.
I lacked the patience and skill. Your fingers must be quite
firm by now :-)
Looks like you might be the boards new candidate for a good
rewinding tutorial so the rest of us have no excuse not to try it.
Once again, Good work Fungus
sPuDd..
« Last Edit: February 29, 2008, 09:40:56 PM by sPuDd »
blueyonder
Re: Rewind finished
« Reply #16 on: March 01, 2008, 05:17:35 AM »
 sum thing i dident mention in the other post .
 the camera work is perfect .
 so again i say .WELL DONE WEE LADDY.
« Last Edit: March 01, 2008, 05:17:35 AM by blueyonder »
fungus
Re: Rewind finished
« Reply #17 on: March 01, 2008, 05:28:33 AM »
Thanks for the compliments :)
But this was a DC motor and with the slots being on the outside of the rotor it was relatively easy to do, with a normal induction motor I'd suspect it'd be a lot harder ..
« Last Edit: March 01, 2008, 05:28:33 AM by fungus »
Re: Rewind finished
« Reply #18 on: March 01, 2008, 05:45:47 AM »
Angus,
It looks VERY impressive indeed. When you mentioned in IRC you were going to take an Ametek apart I was thinking it'd couldn't be rebuilt to factory quality level (and told you so too... :) . But I must admit your job looks at least as good as the original one. I have at times too saved wound rotors (from series commutator motors, as found in drills etc.) to convert to a radial generator (with outer rotating magnet drum). I've even started to unwind some but quickly given up on the task. It takes a lot of effort and care/concentration/accuracy to do it. Kudos.
One thing I notice is that you seem to have filled the slot with more wire than was originally there (higher slotfill). Which is good, I think. But one thing I would add and for which I hope there is still room left is some kind of slot cover to keep the wires in the slots, even though this will be a slow-running generator. In induction motors they sometimes use small, thin (.5 mm) strips of GFRP (epoxy circuit board without the copper). You could perhaps cut up some strips and carefully shove them in? I'd also definitely try to varnish or otherwise secure the windings.
Again, an impressive job.
Peter.
« Last Edit: March 01, 2008, 05:45:47 AM by dinges »
Re: Rewind finished
« Reply #19 on: March 01, 2008, 05:50:19 AM »
I forgot to ask: do you have an estimate for how much time you spent on rewinding that rotor ?
Peter.
« Last Edit: March 01, 2008, 05:50:19 AM by dinges »
fungus
Re: Rewind finished
« Reply #20 on: March 01, 2008, 06:02:45 AM »
I've probably got about 10 hours total into it , about 4 for unwinding, 5 or 6 for rewinding, and a couple just planning what to do ;-)
I am going to secure it all with epoxy, I've ordered that off ebay and it should be here soon, I've made up a small wooden 'cradle' for it to hold it up out of MDF.
I'll probably only get about 25w out of it but its a nice challenge to try :D
« Last Edit: March 01, 2008, 06:02:45 AM by fungus »
Re: Rewind finished
« Reply #21 on: March 01, 2008, 06:09:56 AM »
Awesome work Fungus :>)
 I hope everything works great for ya.Will be cool to see the completed project.
« Last Edit: March 01, 2008, 06:09:56 AM by vawtman »
AbyssUnderground
Re: Rewind finished
« Reply #22 on: March 01, 2008, 06:50:49 AM »
25w is better than nothing!
« Last Edit: March 01, 2008, 06:50:49 AM by AbyssUnderground »
jlt
Re: Rewind finished
« Reply #23 on: March 07, 2008, 06:40:06 AM »
That is a fine looking job you did on that motor.having done several my self.i know how much work it is. the last one that i did was for a electric trolling motor. that was used for a hydro generator. worked well putting about 3 amps output. until water got in and ruined it.i also made several by making them into a alternator.by making commutator into a slip ring. and taking the other end of the winding off of the shaft. much easyer to make and puts out about the same.
« Last Edit: March 07, 2008, 06:40:06 AM by jlt »
