Author Topic: Supplmental Home grid power Project  (Read 938 times)
jzeveney
« on: April 04, 2008, 08:04:03 PM »
System online 03/31/2008
400Watt Wind Generator, Battery Room, Invert room.
http://www.zeveney.com/IMG_6574.JPG
Battery Bank
Current configuration 10 6V Interstate BIMP golf cart batteries ($35 each)
http://www.zeveney.com/IMG_6575.JPG
Also showing AIMS 5000Watt inverter modified sine-wave
Inverter power is brought into home through this.
http://www.zeveney.com/IMG_6576.JPG
This is my home built transfer relay box.  Notice the transformer.  The transformer is powered by the active inverter which energizes the 4 DPDT relay's each pole rated at 30amp.  This allows me to transfer up to eight circuits in real-time.  Should the inverter shut down the relay's automatically open and transfer power back to the utility company.
« Last Edit: April 04, 2008, 08:04:03 PM by (unknown) »
Re: Supplmental Home grid power Project
« Reply #1 on: April 04, 2008, 03:10:54 PM »
 10 megs for 3 photos?
I was looking for the transfer relay.  Didn't find it.
« Last Edit: April 04, 2008, 03:10:54 PM by ghurd »
Old F
« Reply #2 on: April 04, 2008, 03:51:28 PM »
Jzeveney
I am thinking of doing something similar
Where did you get your relays ?
And are you planning  to monitor battery  state of charge so when the batteries  reach set state of discharge It will trade to grid power and trade back when they are recharged
Sound like your having fun
Old F
« Last Edit: April 04, 2008, 03:51:28 PM by Old F »
jzeveney
« Reply #3 on: April 04, 2008, 08:39:08 PM »
Sorry about the large files.
Here are the smaller versions
This is the relay box.
http://www.zeveney.com/IMG_6576_sml.jpg
Batteries & inverter
http://www.zeveney.com/IMG_6575_sml.JPG
Wind Generator
http://www.zeveney.com/IMG_6574_sml.JPG
Z
« Last Edit: April 04, 2008, 08:39:08 PM by jzeveney »
jzeveney
« Reply #4 on: April 04, 2008, 08:52:12 PM »
I purchased the relays from
http://www.mcmaster.com
Part number 7384k43  $23.22 Each
They are working great today.
And are you planning  to monitor battery  state of charge so when the batteries  reach set state of discharge It will trade to grid power and trade back when they are recharged.
Yes. Currently the inverter has a low Battery voltage shutdown around: 10.0 Volts this is to low I think. but that could be the at load voltage I don't know yet.
10Volts will damage the batteries so yes I want to create something which will turn the inverter off when the battery bank drops to 6.20 Volts no load.  I don't know yet what that equates to during inverter load.  I'm plaining to run a 175 amp load tomorrow and monitor the bank voltage before and during the inverter load.
I'm currenlty running 5 pair of 6V deep cycle bats. 6.2 is 25% discharged and should help maintain battery life.  (So I've read.) I may go as low as 6.1 but I'm taking it one step at a time.
Z
« Last Edit: April 04, 2008, 08:52:12 PM by jzeveney »
