Author Topic: Need Help on Batteries  (Read 1195 times)
britt
« on: April 05, 2008, 06:08:30 PM »
First Question: I was give 17 UPS12-140 Batteries. the batteries seem to be dead. can they be brought back to a usable state. how do I check them out.
Second Question: I was also given a second batch a batteries. 31 RBC11_2(2x12V/17AH). They are two batteries stuck together with double sided tape and have a fuse and quick disconnect plug on them. what would be the best way to tie them together into a battery bank to get the best use from them.
« Last Edit: April 05, 2008, 06:08:30 PM by (unknown) »
jzeveney
Re: Need Help on Batteries
« Reply #1 on: April 05, 2008, 12:41:09 PM »
You might try something like the following to bring the batteries back.
http://www.altersystems.com/catalog/bd2-battery-desulfator-p-1251.html
P.S.  I've not tried them so I'd love to hear your results.
Other member here may have better advise on this subject.
Re: Battery Bank
  You need to make certain the batteries are in comparable state and have relatively the same capacitance.
Z
« Last Edit: April 05, 2008, 12:41:09 PM by jzeveney »
Tritium
« Reply #2 on: April 05, 2008, 01:56:49 PM »
If you want to run those RBC-11's at 12V then you have to remove the fuse and connect them parallel rather than in a series as they are manufactured. I also use 8 of these for my Harbor Freight Panels (6 panels). You can cut the batteries apart with a hack saw blade inserted between them to slice the foam tape if desired but I just leave them together and rewire for parallel.
Thurmond
« Last Edit: April 05, 2008, 01:56:49 PM by Tritium »
