Author Topic: delco 10si alternator [CLOSED]  (Read 2584 times)
Southbuck
« on: May 14, 2008, 01:21:34 PM »
My project is a delco 10si with windblue pm rotor. My tests include 3 stators, one 63amp one 37amp and one special wound low wind stator from windblue.
First test
  1. amp stator
  2. 67v dc @400 rpm
  3. 53v dc @1200 rpm
  4. amp stator
  5. 0v dc @400 rpm
  6. +v dc @1200 rpm
  7. 0v ac @400 rpm (from each of 3 phases)
  8. 1v ac @1200 rpm (from each of 3 phases)
windblue low wind stator
(tester overloads @20+ dc volts)
20+ v dc way before my cordless drill is close to 400 rpm
I cant even test dc @1200 rpm, way too much
  1. 3v ac @400 rpm (from each of 3 phases)
  2. 0 v ac @1200 rpm (from each of 3 phases)
Im turning alternator by my cordless drill which has 2 speeds, 400 & 1200 rpm. Each test was run with fresh charged drill battery so all tests started with the same devise at the same charge turning the alternator.
I priced magnets, wire and all the stuff to try to assemble my own alternator but found I was better off letting those who "know" build em. I have nothing lying around I could say "I built this from scraps" so I bought it ALL! That being, the rotor and stator from windblue. Im tickled at the results so far.
Comments disabled on original posters request.
« Last Edit: May 14, 2008, 01:21:34 PM by (unknown) »
finnsawyer
Re: delco 10si alternator
« Reply #1 on: May 14, 2008, 08:51:22 AM »
Ever hear of a "voltage divider"?  It's simply a large value resistor in series with a lower value resistor, such as a 10k in series with a 1k or a 1k in series with a 100 ohm.  Such an arrangement would give you 1/11 the voltage across the lower value resistor as compared to the voltage across the two together.  You can pick the values to get any ratio you like, such as a 9k with a 1k to get a 10 to 1 drop.  You can also get scope probes that have a 10 to 1 drop built in.
« Last Edit: May 14, 2008, 08:51:22 AM by finnsawyer »
Southbuck
« Reply #2 on: May 14, 2008, 12:25:14 PM »
voltage devider? vs cheap tester that will test over 20v dc?
« Last Edit: May 14, 2008, 12:25:14 PM by Southbuck »
