I don't think "Johnny Law" will give you any trouble, as long as you don't get throttle happy!!
By federal law, a max. top speed of 20mph is what defines it as a bicycle, instead of a motorcycle.
I'm not sure what the Denver laws allow at present, but I'm sure changes are being made to accommodate e-bike commuters, if the "powers that be", plan on being re-elected!!
People using the A123 packs have been happy at first, but as time pasted, the range begins to drop off sharply. I think it has to do with cell size and construction, not sure? I'm still doing research on the best battery for my needs!
Yeah, the new battery technologies are getting very interesting!!! The new "Battery Management System" (BMS) that Li battery packs require to keep the cells from going "Chernobyl" is a little scary if you ask me!!!
Using Li battery packs without BMS may result in a catastrophic failure, better known as a "Runaway Thermal Event"!!
Li cells are thermally unstable do to the material the separator plates in the cells are made of. Excessive heat caused by either over discharging or charging a Li cell will cause this separator plate to fail, thus, turning your battery pack and your bike into a BIG 4th of July sparkler (:[ The BMS is just a glorified band-aid that makes Li cells safe enough to use in EV applications, just my opinion.
Yes, I am having second thoughts about building my own Li pack!
Blessings, Snow Crow
