Has anyone heard of the newest craze Hypermiling? I just heard about it a week or so ago on CNN. I had to chuckle, I've been doing this for years...
I thought I was doing really good with my S10 getting 32-35 mpg consistantly. I decided to purchase a ScanGauge III several months ago. Since then I've been getting 41 to 47 mpg. We don't realize how badly we drive or how wasteful we are until you can actually see what we're doing wrong.
This gauge simply plugs into your on board diagnostics (OBDII - 1996 or newer) system and monitors everything that is going on. It also gives you instantaneous MPG which is why I purchased it to begin with.
It should be mandatory that all new vehicles have a MPG gauge installed, you would be quite surprised at how even simple changes in driving habits can save lots of money at the gas pump.
I'm not a hypermiler "extreem" as those shown on CNN... speeding around corners trying not to loose momentum or turning off the engine and restarting it all the time. I'm more of a conservative, casual hypermiler ( safe ). I do coast alot, I've found routes to my normal stops that aren't full of traffic or stop lights just simple things. I've made 2 modifications to my truck that does help as well... I purchased a set of Integrity's - low rolling resistance and run them at sidwall pressure, about 44 lbs. I also installed a set of pulstar plugs but I only picked up 3 mpg with those.
I'm not affiliated with the ScanGuage in any way, I simply think it is a must have for those trying to save some money on fuel.
On the other end of things, you can now convert your car/truck to a hybrid. Transwarp motors are designed to connect behind the transmission, and has a tail shaft built in for sliding a shorty driveshaft to the rear end. The control box connect directly to your OBDII outlet and controlls the elecric motor based on throttle position. As a plug in hybrid this could actually save a considerable amount of fuel. Unfortunately, the units are still quite expensive and converting a vehicle could cost 5-6k by the time your done. The payback would take a while depending on how much you normally drive.
Lots of neat stuff on the horizon... hopefully it will become more affordable so all can participate. Right now it seems only the rich can save money, the rest of us pay out the bun's to barely break even with the costs...
