Author Topic: 2008 summer progress part 2.  (Read 1176 times)
margusten
« on: October 07, 2008, 12:44:32 PM »
Hello,
Now satellite dish removed and 20W solar panel on polar mount.
May be next summer I can add motor and some tracking electronics.
Inside of cellar I have 12 2V batteries. Now connected 12V and 900Ah.
And little bit modified old controller.
Only problem seems to be moisture. You can see small water bubbles. How long can electronics work in such place?
Tried new 4 PVC blade set on new alternator. Works but not as good 3 PVC blade set before. Probably too thin blades.
More news coming soon.
Margus
Margus: This will be interesting for many users but please re-post this Diary using resized photos, 1648px × 1171px images not allowed!
Photo Size is limited to 150K bytes and/or 640x480.. Please adjust your photos before posting them, whether they are on our server or yours. If you post large images, it causes large problems for other users who have slow internet connections and/or small screens.
Frequently Asked Questions
« Last Edit: October 07, 2008, 12:44:32 PM by (unknown) »
Airstream
Re: 2008 summer progress part 2.
« Reply #1 on: October 07, 2008, 11:18:43 PM »
Hope he posts back...
« Last Edit: October 07, 2008, 11:18:43 PM by Airstream »
margusten
« Reply #2 on: October 08, 2008, 01:11:31 AM »
Sorry about oversized pictures,
Again with pictures.
Margus
« Last Edit: October 08, 2008, 01:11:31 AM by margusten »
« Reply #3 on: October 08, 2008, 02:00:26 AM »
 Moisture will take it's toll . Put your controllers in another enclosure .Calculate the highest wattage and install a resistance 20 percent higher than the max wattage to dry the air somewhat in windy weather .
« Last Edit: October 08, 2008, 02:00:26 AM by tecker »
« Reply #4 on: October 08, 2008, 09:50:00 PM »
I see you have the batteries on wood boards and shoved into the corner.
The insulation between them and the floor is good - helps to keep the batteries from stratifying and getting a voltage gradient driven by a temperature gradient.
But better would be to pull them out from the wall and adjust the supports under them so air can circulate all around 'em.
Also:  Be sure to vent the area so you don't have hydrogen and acid droplets collecting in the area.  (That will also help with the condensation.)  It only takes a LITTLE venting to avoid explosions and corrosion.
« Last Edit: October 08, 2008, 09:50:00 PM by Ungrounded Lightning Rod »
