Author Topic: Got a Bicycle Computer Today  (Read 1224 times)
valterra
« on: November 30, 2008, 11:25:45 PM »
$10 at Target, or $15 for a more advanced one.  The advanced one had lots of features we wouldn't use, except it did say it gave the temperature.
I set it to 1667mm as suggested in another post, and tested it.  As far as I can tell, it works correctly.  Just have to multiply the kp/h by 10 to get the RPM.
Anyhow, before I went through any trouble of climbing up onto my roof, I cut the wires and put a 500 foot spool of Cat-5e between the sensor and the computer.  Tested again - same results.  Yay!
I thought there'd be something fancy like the magnet creating voltage spikes that the computer measures.  The very faint clicking sound tells me that it is a simple reed switch.  The GOOD news about this is that if the sensor gets ruined by the elements, any Normally Open reed switch should work as a replacement.  Surplus Center has them for about 2 bucks.  As confirmation, I quickly shorted out the wires many times and saw the reading on the computer.
Now if I could just translate it into my ACTUAL computer easily (read: CHEAPLY) I would be all set!
« Last Edit: November 30, 2008, 11:25:45 PM by (unknown) »
Re: Got a Bicycle Computer Today
« Reply #1 on: December 01, 2008, 06:29:04 AM »
All the ebay elcheapos have an rpm setting
« Last Edit: December 01, 2008, 06:29:04 AM by tecker »
valterra
« Reply #2 on: December 01, 2008, 08:00:43 AM »
Cool.  I may try one for my next genny.  For now, the (.) in the middle doesn't bother me.
« Last Edit: December 01, 2008, 08:00:43 AM by valterra »
« Reply #3 on: December 01, 2008, 10:10:44 AM »
Since the sensor is a simple reed switch, you could feed the pulses into any pulse-counting data logger.  Depending on the setup, the reed switch will need +V supplied.
I have dreams of connecting a cycle computer reed switch to my PicLog, but counting the AC pulses works (barely) well enough to prevent me from diving in.
« Last Edit: December 01, 2008, 10:10:44 AM by SparWeb »
« Reply #4 on: December 01, 2008, 10:36:41 PM »
Could we get a few examples?
« Last Edit: December 01, 2008, 10:36:41 PM by ghurd »
valterra
« Reply #5 on: December 02, 2008, 04:08:03 PM »
That piclog looks interesting!
Especially since whenever I hook up a new meter, all I want to do is stare at it.
It wasn't windy today, but the "max speed" on it says 685 rpm.  Whoa nelly.  I can't wait to see what happens during a real blow.
(This is on my 4' Ametek genny with crappy blades).
« Last Edit: December 02, 2008, 04:08:03 PM by valterra »
