Author Topic: Blade plans  (Read 1446 times)
trumpets3u
Blade plans
« on: February 15, 2009, 06:27:25 PM »
Does some one out there have better pictures or clearer plans for carving blades for the 10' turbine?
                 Thanks Brian
« Last Edit: February 15, 2009, 06:27:25 PM by (unknown) »
lglagasse
Re: Blade plans
« Reply #1 on: February 15, 2009, 12:21:06 PM »
Did you try the "FAQ" section, here, upper right. Decent pictures under blades 101. Hugh Pigott has good description in his book.
lglagasse
« Last Edit: February 15, 2009, 12:21:06 PM by lglagasse »
halfcrazy
Re: Blade plans
« Reply #2 on: February 15, 2009, 12:30:16 PM »
yep or Dan's new book "Homebrew Wind Power" has all the info you could ever want on there 10 ft machine. i highly recommend getting it and reading it before you do anything. then apply what you want and change what you want but the book will really shed new light on the turbine and how it works and how to build it.
« Last Edit: February 15, 2009, 12:30:16 PM by halfcrazy »
trumpets3u
Re: Blade plans
« Reply #3 on: February 15, 2009, 01:04:53 PM »
Thanks the book is on it's way. I ordered it last Thursday.
                     Brian
« Last Edit: February 15, 2009, 01:04:53 PM by trumpets3u »
halfcrazy
Re: Blade plans
« Reply #4 on: February 15, 2009, 02:02:44 PM »
it will help you a lot it is very detailed they id a great job on it. I ended up having one of Dan's neighbors build me a set of blades i just didn't feel like carving them. although it seems like it isn't to bad once you get the hang of it?
« Last Edit: February 15, 2009, 02:02:44 PM by halfcrazy »
bzrqmy
Re: Blade plans
« Reply #5 on: February 15, 2009, 06:25:27 PM »
Although the book has a lot of great information, the pictures are reduced and in B&W.  I used a combination of the book and the 10' instructions on this website.  I just finished my blades.  I understand why he is looking for better pictures.  In my opinion, you can never get enough pcitures.
« Last Edit: February 15, 2009, 06:25:27 PM by bzrqmy »
halfcrazy
Re: Blade plans
« Reply #6 on: February 15, 2009, 06:27:35 PM »
Agreed and if it would help you can always come check out mine that scott carved they are the ones they sell here
« Last Edit: February 15, 2009, 06:27:35 PM by halfcrazy »
hvirtane
    • About Solar Cooking
Re: Blade plans
« Reply #7 on: February 16, 2009, 09:26:38 AM »
« Last Edit: February 16, 2009, 09:26:38 AM by hvirtane »
imsmooth
Re: Blade plans
« Reply #8 on: February 19, 2009, 08:21:15 PM »
I don't know if this helps, but try this
http://www.mindchallenger.com/wind/wgpage15.html
I used a chainsaw to carve the profile using Oztule's method.  The blades worked great until the tail hit them.  I am making another pair now using pine.  You can see them getting laminated here
http://www.mindchallenger.com/wind/wgpage18.html
My experience pales compared to most here, but having just done it, and now doing it again I might be able to help.
« Last Edit: February 19, 2009, 08:21:15 PM by imsmooth »
