Author Topic: I think I'm on the right track now  (Read 4215 times)
« on: April 08, 2009, 05:30:21 PM »
  The exercise bike with a little generator
was very inefficient 15 watts...the new one,
David Butcher's style works a lot better, I have
a 3" driven pulley and I get something like 30
watts....I'm hoping I can get close to 45 watts
with a 2 " pulley well anyhow .....
Yep that's your Ametek TomW ! It's sure found a
lot of uses....Handy little gadget !
  This machine is so easy almost like it isn't
even connected but looking at the ammeter at 2.1
amps and the voltage at 15.4 tells me it must be
working....I try to get in about 2hrs 20 minutes
at a time....usually I catch myself daydreaming
forgetting the time and I've been pedaling for
almost 30 minutes instead of the 20.
Fun! The snow has melted and it's like spring
here in Conneaut!
« Last Edit: April 08, 2009, 05:30:21 PM by (unknown) »
Re: I think I'm on the right track now
« Reply #1 on: April 08, 2009, 11:33:46 AM »
Norm;
Wow!! I just noticed that it was direct drive!! What's the size of the flywheel?
« Last Edit: April 08, 2009, 11:33:46 AM by Bruce S »
« Reply #2 on: April 08, 2009, 01:07:59 PM »
Now we all know how
"Norm- The Enforcer"
Stays in shape!
« Last Edit: April 08, 2009, 01:07:59 PM by ghurd »
« Reply #3 on: April 08, 2009, 02:15:52 PM »
Bruce, It started out as 36 inches diameter...
but then it was a little bit off center and
by the time I took a router to turn off some
of the edge and (oopsie !)it is something like
....35" ?? so with a 3" pulley the ratio is like
.....1:11.2 ?? So when I crank it at 60 rpm its
spinning the Ametek about 660rpm.
  It is neat !
« Last Edit: April 08, 2009, 02:15:52 PM by Norm »
« Reply #4 on: April 08, 2009, 02:37:22 PM »
cool norm...
« Last Edit: April 08, 2009, 02:37:22 PM by hiker »
« Reply #5 on: April 08, 2009, 02:42:59 PM »
Ahh;
Now the troops are all coming together :)
We have TomW aka Robo ED 2.0
G- aka FAQ writer GURU
Norm aka "The enforcer"
Norm ( enforcer) that's a good way to get those up to speed, are you using a charge controller? or direct?
« Last Edit: April 08, 2009, 02:42:59 PM by Bruce S »
« Reply #6 on: April 08, 2009, 03:45:31 PM »
Pretty neat, Norm.
Gonna be ripped and lean with abs like concrete blocks powering the house with that.
I can't seem to lose any weight watching turbines spin and panels soaking up sun.
Fun stuff, anyway, huh!
« Last Edit: April 08, 2009, 03:45:31 PM by TomW »
zap
  • There's an app for that
« Reply #7 on: April 08, 2009, 05:02:15 PM »
Nice Norm, I'm glad your results are getting closer to your liking.  How noisy is it?
It's time here for the annual "trade your trash" event.  I'll try and keep an eye out for a mower.
« Last Edit: April 08, 2009, 05:02:15 PM by zap »
« Reply #8 on: April 08, 2009, 10:08:18 PM »
It would be pretty quiet if it had a soft plastic
roller skateboard wheel instead of a rubber hose
tire on a wood plug...I think the rubber hose
probably has s lump in it gives it a low rumble,
I'd never be able to run it at 2 AM....???
« Last Edit: April 08, 2009, 10:08:18 PM by Norm »
« Reply #9 on: April 08, 2009, 10:15:20 PM »
I'm using a full-wave rectifier direct to a
battery ....no need for a charge controller....
no chance I'll ever overcharge a battery I doubt.
« Last Edit: April 08, 2009, 10:15:20 PM by Norm »
zap
« Reply #10 on: April 08, 2009, 10:24:41 PM »
I tried a few different ways to quite things down.  Before I went with the current v belt I tried a roller blade wheel on the bare MDF but it slipped too much.
Then I tried a rubber bike tire liner on the MDF.
Then I cut down a bike tube.
Both of these would eventually work their way off the MDF so I tried hot gluing them to the MDF and that didn't work well either.  Too much area to try and glue all at once.
The v belt is very quite... I'd say 90% of the noise is from the motor/generator.  If it used a dual rotor axial I have a feeling it would near silent.
« Last Edit: April 08, 2009, 10:24:41 PM by zap »
« Reply #11 on: April 09, 2009, 10:59:19 AM »
A roller blade wheel on this is very quiet and
no slippage...but it's about 4 inches, a 1:9 ratio, so when you're pedaling at 60rpm that's too
slow 540 rpm only get about 15 watt charging rate
, I've been thinking about trying a dryer belt on
a treadmill motor but I'd have to make the flywheel about 30inches instead of 36 and a new
dryer belt cost $30 or unless I go dumpster
diving and then come to find out that was why they
got rid of the dryer in the first place...broken
belt.
   Gotta go fix my recliner....if they had used
just a bit heavier braces....2 extra wood screws
next size bigger it would have went 20yrs
instead of 10.  Just think 20 cents extra on a
 $300 chair?
« Last Edit: April 09, 2009, 10:59:19 AM by Norm »
« Reply #12 on: April 09, 2009, 12:09:39 PM »
what happened to the flywheel that was on the bike?
did you try running a flat belt off of that down to your gen?
seems like you would get less friction and drag using the flywheel on the bike..
just my thoughts.....hey its a blast any which way..
i finally wore out the front bearing on my 300v ac pedgen alt..just watching tv-stereo.
playing records........
ps..  stop by a auto shop--should be able to get a used auto flat belt for free..
« Last Edit: April 09, 2009, 12:09:39 PM by hiker »
« Reply #13 on: April 09, 2009, 12:20:59 PM »
heres a shot of my little 300v ac pedgen NORM..
real simple set up--gen is  bolted to a scrap piece of plywood
bike is moved forward to mount belt--slid bike back to tighten belt
then your body weight is all that is needed to keep the belt tight..
« Last Edit: April 09, 2009, 12:20:59 PM by hiker »
Electron Pump
« Reply #14 on: April 10, 2009, 07:59:37 PM »
  I havent had a chance to show anyone this ped jen, I think I'll take the opportunity to do so now. She worked, but not very good. She needs a perminent magnet motor. Thats right boys... Thats a bone stock Jeep alternator. And I tell ya, It was all I could do to get it up to charg volts.
  One advantage to design... I've still got gears to get those coils all excited. Another is I can put a tire back on her and go to town for a beer.
« Last Edit: April 10, 2009, 07:59:37 PM by Electron Pump »
« Reply #15 on: April 10, 2009, 08:47:10 PM »
if you lower the volts-amps- going to the field coil--it will be a lot easyer to
pedal--hook up a 12v tail light bulb in series with the wire going to the field coil..
you should still be able to get 250+ watts that way..if you want more amp output
add another bulb[or more] in parell with the first one...[will be even harder to pedal]
i just hit the field coil with a 9v trasiter radio batt. for a secound or so..
then the field coil kicks in and theres no need for a batt. you can slow your pedgen down to a crawl and still get power output--as long as the load is not to big..
otherwise you lose your field coil voltage and will have to do a restart..
check my pedgen files if you want..   fun stuff
           http://www.fieldlines.com/story/2007/7/31/93955/8934
« Last Edit: April 10, 2009, 08:47:10 PM by hiker »
« Reply #16 on: April 12, 2009, 09:18:01 PM »
Wish I had your variety of motors to experiment
with but it's just plain fun to see how I can get
the most out of what I have.
  You really impress me how you can get things
to work seemingly so effortlessly and simply.
I do have one little trick I'm going to try with
a treadmill motor and it will be very quiet....
(the particle board flywheel in place of the bike
wheel)would be a 1:24 ratio about 1400rpm of the
motor when pedaling 60 rpm.
« Last Edit: April 12, 2009, 09:18:01 PM by Norm »
« Reply #17 on: April 12, 2009, 09:23:39 PM »
Have you tried charging a low 12volt battery in
top gear with this?
« Last Edit: April 12, 2009, 09:23:39 PM by Norm »
Electron Pump
« Reply #18 on: April 13, 2009, 07:20:24 AM »
  Yessir. Its hard when you get started but eases up after about thirty seconds or so. I call it "getting over the hump!"
« Last Edit: April 13, 2009, 07:20:24 AM by Electron Pump »
« Reply #19 on: April 14, 2009, 09:04:21 AM »
 Electron Pump,
   'Getting over the hump' as you call it, If you
have a watt meter or use a couple of multimeters
like I do occasionally getting the voltage and
the amps readout you might notice on a low battery
that it probably cuts in early but then it will
putting in a lot of amps, but then it brings the
battery voltage up quickly (my theory) once the
battery voltage gets up higher the charging rate
goes down (I've noticed that 6 volt battery paks,
with fairly large capacity is harder pedaling than
12 or 24 volt)
BTW I try to put this on 'hot list' so I don't
miss interesting feed back.
I'm really trying to do the flywheel to friction
pulley thing....David Butcher succeeds in doing
about 150 watts with his setup so I see no reason
why I can't do the same...but I keep an open mind
and if someone can convince me otherwise ???
I want something simple efficient and quiet...
I've got the belt and auto alternator...(someplace)
« Last Edit: April 14, 2009, 09:04:21 AM by Norm »
