At the townhouse we had a goose hit a primary line in our neighborhood. The current through the goose at 12 KV was enough to melt through the #10 wire in several places and drop it. (I figure the goose probably dissipated over a megawatt for a couple seconds. If it had only pulled 30A for a dissipation of 0.36 megawatts the wire wouldn't have failed. DON'T climb the pole and touch the primaries!)
Our neighborhood had about 100 houses on a bank of 3 (paralleled on a single phase) transformers and the primary lines went down BETWEEN the transformers. So PG&E had to unhook the whole neighborhood from the grid before bringing the power back up on the rest of the outage block, then replace several dropped primary runs before they could hook the neighborhood back up. Took from some time midday (when the goose hit) to after 1 AM.
I had a small gas genny which I used to power up the house by backfeeding the trailer outlet - AFTER dropping the mains breaker (and putting a piece of blue tape over the area where the toggle would be in "on" mode for a reminder not to turn it on until the genny was unhooked). Used it for the refrigerator, a little lighting, and the TV. Had the only lit house on the block.
Of course the linemen came by to make sure I wasn't backfeeding the transformer before working on it. I was able to show them that I knew what I was doing and they would be safe, so they let me leave it running.
(This was the time I bumped the test button on the $80-ish trailer GFCI breaker while it was being backfed and discovered that this permanently demoted it to an overcurrent breaker. B-( So I got to buy another one. But it's worth it to know WHY they say not to backfeed them.)
At the Nevada place we've had a lot of outages. Mountain storms, once a fire on our block under a transformer. These can take a day or more to bring back. When we're not there the 'fridge keeps the food cold long enough. But when we ARE there heating by the milivolt-stat propane fireplace (with the blower non-functional), reading by candle-lanterns, and having only radio for news is a pain.
So when we move there for retirement we'll need a UPS.
And by doing the UPS - which we'd need whether RE or grid-tie-only - as a RE battery bank and grid-charging/bypass inverter rather than a purpose-built UPS-only device, we reduce the capital cost of a RE system to the generation system plus the premium on the inverter/battery above a UPS-only. That should help get us closer to financial break-even, reducing the amount of "having fun building it" and "feel good having it" components of the value equation needed. B-)
