Going over my notes from solar power recorded from the last two months this is a summary of what the mx 60 and trimetric have recorded.
The Folowing is a really rough averaging of my notes.
This is for the Lac La Biche area of Alberta.
June and July
1000 watts of solar panels are producing a average of 200 amp/hrs per day.
The weather has been mainly sunny and 30C
Charging starts at 8:00 am (100watts) and continues to 4:00 pm.
Max charging is from 11:00am to 3:00 about 800 watts
Battery voltage averages a low of 23.5 volts to a high of 27 volts.
I need to hit 28 volts before batteries are full.
battery percent has been from 75% to 95 average.
The Hornet winmdmiil has takin a good beating in some storms.
1 night of 50km/hr winds was actually adding to the batteries.
Winds are from the Northwest. More trees to cut.
My residence is using roughly 176 amp/hrs per day.
That is running a 60 watt ac window fan, 4cu ft danby freezer, tv and satellite for 5 hrs/day (curse of soap opera).
we use a 1/3hp ac jet pump pumping about 75 gallons/ day (gotta keep the horses watered)
Used the genset twice to top up the batteries during some cloudy weather.
I start it at night and let it run till morning about 8 hrs.
0.75 liters/hr. ( Just buy 20 l can and dump it in the tank, 75cents/L)
3000 watt deutz diesel charging through magnum 4024 at 40 amps.
Done 2 equalize cycles.
Equalize cycles I plan by using the genset at night to top up and let leave town for the day so the solar panels can equalize.
Crunching numbers last night pretty much showed I need another 400 watt of panels.
Power company still wants $5300 for pole and trans, then 500 per pole.
11 grand to bring line in!
Muskeg
