Author Topic: Solar Panel Array  (Read 1816 times)
kwdaye
Solar Panel Array
« on: July 31, 2009, 07:54:51 AM »
Does anyone have any plans on how to build a solar array for solar panels, something like the picture?
« Last Edit: July 31, 2009, 07:54:51 AM by (unknown) »
kwdaye
Re: Solar Panel Array
« Reply #1 on: July 31, 2009, 02:13:45 AM »
Picture located at http://home.fuse.net/kwdaye/Kevin/Photos.html
I would like to build one, I have resource where I can get the material real cheap if not free, but I need the plans or plans for one.
thank you
« Last Edit: July 31, 2009, 02:13:45 AM by kwdaye »
tanner0441
« Reply #2 on: July 31, 2009, 11:06:03 AM »
Hi
What do you mean plans?  What size panels, how many do you want to use, what voltage, and your picture looks like a tracking setup. Look on this board and you will find photos of loads of arangements from the simple to the phenomenal.
Plans could be for anything from a simple framework holding the individual panels at the correct angle. To a full sun following array.
Brian.
« Last Edit: July 31, 2009, 11:06:03 AM by tanner0441 »
kwdaye
« Reply #3 on: July 31, 2009, 06:53:33 PM »
Just starting out right now, I guess what I'm looking for is just the basic setup or some kind of starting point, only have a couple of panels but want to expand sometime in the near future. Guess I'll just look around some more.
Kevin
« Last Edit: July 31, 2009, 06:53:33 PM by kwdaye »
kurt
    • website
« Reply #4 on: July 31, 2009, 07:10:27 PM »
have you tried following your nose like clicking the otherpower link at the top of every one of this boards pages and then following the links at the bottom of that page and then following though on the links you find there?? start here http://www.otherpower.com/ follow your nose from there there are basic solar power system pages on that site.
« Last Edit: July 31, 2009, 07:10:27 PM by kurt »
« Reply #5 on: July 31, 2009, 07:27:34 PM »
"Basic set up"?
You mean a suitably sized rectangle with holes drilled in the correct place to hold the PVs, mounted on a pipe so the PVs face South?
If so, make a suitably sized rectangle with holes drilled in the correct place to hold the PVs, mounted on a pipe so the PVs face South.
If you mean how to make the PVs turn toward the sun, the term is known as "tracking",
and there is no 'basic' tracking.
« Last Edit: July 31, 2009, 07:27:34 PM by ghurd »
rossw
« Reply #6 on: July 31, 2009, 11:52:38 PM »
Is something like this suitable?
[img width= height=]http://house.albury.net.au/26jul2009/thumb.100_3584.JPG[/img]   [img width= height=]http://house.albury.net.au/26jul2009/thumb.100_3586.JPG[/img]
(click the images for higher-resolution)
This is a 1200-watt array I just built last weekend. It has seasonal adjustment (could be manual, but if you look closely you will see the actuator I have on mine).
It's also extensable - one more post per 4 more panels and a couple of bits of steel to join them on.
I've designed this to be EASILY tipped, hence it's balanced with approximately equal weight either side of the pivot. I can tip this one with one hand - even though it weighs over 150Kg.
« Last Edit: June 03, 2011, 06:32:10 PM by rossw »
kdaye
« Reply #7 on: August 01, 2009, 02:18:04 AM »
Yes, that one looks nice, can you adjust it for seasonal changes? Looking at the picture from the front view, is that a smaller on to the right of the big array and if so do you have any pictures of it up close?
Thank you,
Kevin
« Last Edit: August 01, 2009, 02:18:04 AM by kdaye »
rossw
« Reply #8 on: August 01, 2009, 04:42:49 AM »
I said: "This is a 1200-watt array I just built last weekend. It has seasonal adjustment (could be manual, but if you look closely you will see the actuator I have on mine)."
You seem even less capable of understanding plain english in the forum than you were in IRC!
It's a dual-axis tracker, and yes I have lots of photos of it.
« Last Edit: August 01, 2009, 04:42:49 AM by rossw »
kdaye
« Reply #9 on: August 01, 2009, 06:39:30 AM »
ok, sorry for that, I would tell you why but you would probably say I'm just making excuses. So, with that said, would you kindly like to share them with me. Please !!
Thank you,
kdaye
Have a nice day !
« Last Edit: August 01, 2009, 06:39:30 AM by kdaye »
