Author Topic: minnie alt-400 watt-28v-pedgen  (Read 2626 times)
« on: August 28, 2009, 10:53:53 AM »
found this little motor when i cleaned out the basement-it was a 1/3hp single phase.
now - 8 and 6 combo-but with 12 coils-two sixs-wired in star[both]..
two mags per pole[neos]--42 winds per coil on the outer coils--32 on inner coils..
mags are not angled-you can feel each lam as you slowly turn the shaft[24]..
no real cogging -untill you short the alt out--then its real hard to turn over by hand.
 time to try it out on the pedgen..first i hooked up 3 50watt headlites to it--wasnt
easy but not really that much of a strain...hmmm dug out my 400-1000watt dual element
28v aircraft landing light..been trying to lite that sucker up for some time now!!!
 first try i hooked it up to the 400 watt clips--jumped on the pedgen--started off
kinda slow and let the speed build up--dammed if i didnt hit 27-30volts..
 fun toy..it has no bearings just bushings..never thought i would get that much power
from such a small motor!---1000watts dream on-only got up to 13 volts -volt meter
would clime no higher even with a faster RPM...........
heres a few picts and a vid link............
http://www.youtube.com/watch?v=kRYfp9YrnTU&feature=channel
« Last Edit: August 28, 2009, 10:53:53 AM by (unknown) »
KilroyOdin
Re: minnie alt-400 watt-28v-pedgen
« Reply #1 on: August 28, 2009, 06:03:55 AM »
Hi, very nice. I really liked the video. What are the RPM's at the PMA?
« Last Edit: August 28, 2009, 06:03:55 AM by KilroyOdin »
zap
  • There's an app for that
« Reply #2 on: August 28, 2009, 08:10:12 AM »
Nice hiker, and a very respectable output.
Where did the coil wire come from?  Wiring harness?
« Last Edit: August 28, 2009, 08:10:12 AM by zap »
« Reply #3 on: August 28, 2009, 08:41:25 AM »
Great work hiker. Do you have an amp meter to place in this test?
I would get a kid to push the peddels while you run the camera.
Good to see your still building proggects like this.
Zubbly (RIP) is pleased I'm sure.
« Last Edit: August 28, 2009, 08:41:25 AM by Jerry »
FishbonzWV
« Reply #4 on: August 28, 2009, 03:01:58 PM »
Nice job there hiker.
I bet you're the only person in the world with that fancy colored magnet wire ;-).
I suppose you got to use that new lathe to turn the rotor down, if you did how did it go? Give some spec's on the turning.
Bonz
« Last Edit: August 28, 2009, 03:01:58 PM by FishbonzWV »
H.F.Fisher 1925-2007
« Reply #5 on: August 28, 2009, 11:11:54 PM »
fishbonz...
 thats not magnet wire--just a old spool of plastic insulated wire i had laying around..like 5 strands--had to unweave each strand to make the coils[boring]..
 still havent found a good hard bit for my lathe--being it was such a small rotor
i used a hacksaw--didnt really take that long...
 i did use the lathe to turn down the wooden pully-work great for that....
  not sure what size that wire is--maybe 19-21 ??
« Last Edit: August 28, 2009, 11:11:54 PM by hiker »
« Reply #6 on: August 28, 2009, 11:58:04 PM »
hey jerry..
i do have a meter--just have to borrow it off of my pedgen..
would be nice to see the actual amps.
would have to have the kids run the camera -if i did any more tests with the
landing light--takes a lot of hard cranking to hit 27-30volts..
glad to see you back as well--been keepin a eye on all your tests as well...
for me its just a hobby--but for a lot a pepole its a real thing...
« Last Edit: August 28, 2009, 11:58:04 PM by hiker »
« Reply #7 on: August 29, 2009, 12:05:09 AM »
kilOdin.
 no idea on the rpms--my spedo was hitting over 30+ mph.........
that old exersize bike is geared kinda high--had to have a fairly big pulley on
the alt to spin it over-could use a slightly bigger one--there easy to make--just
cut out some plywood disks and bolt togeather...........
« Last Edit: August 29, 2009, 12:05:09 AM by hiker »
« Reply #8 on: August 29, 2009, 12:09:06 AM »
zap.......
just a old spool of wire i had laying around-about 5 strands-plastic coated..
its not mag wire--but it is solid copper.........
« Last Edit: August 29, 2009, 12:09:06 AM by hiker »
FishbonzWV
« Reply #9 on: August 29, 2009, 02:40:16 AM »
Yeah, I was just pullin' your chain on the wire.
I use the center bit for my rotor turning.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40637
My tool post is only 1/4" though, yours could be 5/16".
« Last Edit: August 29, 2009, 02:40:16 AM by FishbonzWV »
« Reply #10 on: August 29, 2009, 01:07:28 PM »
thanks fot the tip- on bits.............
« Last Edit: August 29, 2009, 01:07:28 PM by hiker »
