I can see the end! I found an old switch for some sort of large machinery and installed it next to my tower. The box is indoor rated but should work fine for shorting out the turbine at the tower. I know it's a bit of overkill, but it looks nifty and is easy to operate. I'm still going to use the plug idea for untwisting the pendant cable, it will just be plugged into this box instead of a socket laying on the ground.
It's about 150' to the power shed. I found a spool of telephone wire with something like 8 twisted pairs and decided to run it in the conduit as well. Maybe I'll want a hard wired anemometer or something someday, and the wire will be there.
I also built my stub today. I needed something to fit down inside 2" Sch40 I think the next size down was 1.5" and it was a real sloppy fit with sch40, but sch80 fit like a charm.
I carved up a nylon/plastic cutting board for the bearing. I read somewhere in here of people doing that so I copied the idea.
Oh, and lastly. Here's why not to use polyester on your rotors. This thing has never even been in the air, just sat in a garage for 3 years with temperatures from -10F in winter to 100F in summer. I spun it around by hand, shorted two phases to stop it and this is what happened! I'm either going to upgrade to round magnets or band these rotors before trying to fly this thing.
