Author Topic: water volume  (Read 4766 times)
mbk
water volume
« on: October 24, 2009, 09:23:26 PM »
hi i an working on a outside wood furnace and was wondering if any one wounld know how much water a 36inch diamator pipe 34 inches tall would hold.  thanks for any answers i tryed 18sq times 3.14  times the highth but wasnt sure if that was how been to long since ive had to use geo thanks again for your help you have a nice site here i really like the wind.
« Last Edit: October 24, 2009, 09:23:26 PM by (unknown) »
wpowokal
« Last Edit: October 24, 2009, 09:32:40 PM by wpowokal »
mbk
Re: water volume
« Reply #2 on: October 24, 2009, 09:37:36 PM »
thanks wpowokal
« Last Edit: October 24, 2009, 09:37:36 PM by mbk »
frepdx
Re: water volume
« Reply #3 on: October 24, 2009, 10:30:31 PM »
I've used convert for years. easy to find volume in inches but always a pain to convert to gallons :)
http://joshmadison.com/software/convert-for-windows/
« Last Edit: October 24, 2009, 10:30:31 PM by frepdx »
wdyasq
Re: water volume
« Reply #4 on: October 25, 2009, 05:22:27 AM »
The formula is area of bottom X height. As the tank is circular, the area of the bottom will be pi X r^2.
For a simple quick calculation we will convert to feet. 1.5^2= 2.25; 3.14X 2.25= 7.06;
7.06 X 2.83 = 19.99 - let's call that 20 cubic feet. There are approximately 7.5 cubic feet to a gallon so 7.5 X 20 = 150 gallons. The water weighs 62.5lb/ft X 20ft = 1250 lb.
« Last Edit: October 25, 2009, 05:22:27 AM by wdyasq »
Re: water volume
« Reply #5 on: October 25, 2009, 05:48:55 AM »
Ron;
For accuracy sake I think you meant "approximately  7.5 gallons per cubic foot"?
Transposed the units.
Not sure of the exact # .
Tom.
« Last Edit: October 25, 2009, 05:48:55 AM by TomW »
wdyasq
Re: water volume
« Reply #6 on: October 25, 2009, 06:36:34 AM »
Thanks for the correction...
« Last Edit: October 25, 2009, 06:36:34 AM by wdyasq »
Re: water volume
« Reply #7 on: October 25, 2009, 06:37:11 AM »
Buick 231cid V6.  1 Gallon.  :)
« Last Edit: October 25, 2009, 06:37:11 AM by ghurd »
mbk
Re: water volume
« Reply #8 on: October 25, 2009, 08:17:12 AM »
thank you all for all the help ive put my second mill on hold till i get this wood firnace done then back to buildin my mill   thanks again
« Last Edit: October 25, 2009, 08:17:12 AM by mbk »
gizmo
    • The Back Shed
Re: water volume
« Reply #9 on: October 25, 2009, 03:44:21 PM »
Good grief.
"water weighs 62.5lb/ft"
give me metric anyday.
1meter cubed of water = 1000 litres of water = 1 ton
water boils at 100C, freezes at 0C
Its all so simple, not weird numbers to remember
Mind you, a foot long hotdog sounds better than a 300mm hot dog.
« Last Edit: October 25, 2009, 03:44:21 PM by gizmo »
wdyasq
Re: water volume
« Reply #10 on: October 25, 2009, 04:12:14 PM »
Is that a metric ton, a long ton, an American ton or an Imperial ton. ..... or, maybe you meant tun?
40 years ago the US goobernment decided to change to metric. This was after several proclamations of going metric dating back to the 18th Century.
BTW, anybody know a good converter for Furlong to kilogram?
« Last Edit: October 25, 2009, 04:12:14 PM by wdyasq »
rossw
Re: water volume
« Reply #11 on: October 25, 2009, 04:15:56 PM »
Slight correction, Giz!
1000 litres of water = 1 tonne. (metric)
1 ton is 2204 lbs, which is only 999.7Kg.
« Last Edit: October 25, 2009, 04:15:56 PM by rossw »
frepdx
Re: water volume
« Reply #12 on: October 25, 2009, 05:03:24 PM »
"BTW, anybody know a good converter for Furlong to kilogram?"
In google search, type;
"furlongs in one mile"
Or, you can use convert
« Last Edit: October 25, 2009, 05:03:24 PM by frepdx »
gizmo
    • The Back Shed
Re: water volume
« Reply #13 on: October 25, 2009, 06:12:49 PM »
Ah whats 300 grams between friends.
But your right, it is spelt tonne and not ton in the metric system.
« Last Edit: October 25, 2009, 06:12:49 PM by gizmo »
bob golding
Re: water volume
« Reply #14 on: October 26, 2009, 04:32:28 AM »
at what pressure and temperature? 25c and sea level? here in  the UK we use metric but i was brought up on imperial so i have to ask for a piece of 100mm x50mm but still think of it as 4x2. agree metric is easier to calculate with.
bob
« Last Edit: October 26, 2009, 04:32:28 AM by bob golding »
Re: water volume
« Reply #15 on: October 26, 2009, 12:55:50 PM »
Unix "units" command says 7.4805195
That ought to be close enough.  B-)
« Last Edit: October 26, 2009, 12:55:50 PM by Ungrounded Lightning Rod »
Re: water volume
« Reply #16 on: October 26, 2009, 01:16:25 PM »
English units have some advantages.
For instance:  Farenheit:
 * 100 degrees was intended to be the normal internal temperature of a healthy, awake, resting human, though the scale originally set mouth temperature as 98 for a proxy.  (Typical "normal" is 98.6 under the tongue, 100.6 rectal, after the scientists tweaked it to make the freezing and standard-pressure boiling points of water exactly 180 degrees apart, so they got it pretty close.)  Makes understanding fever readings easy.
 * zero degrees is the melting point of water in saturated (ammonium chloride) salt solution - the coldest reliable temperature they could create in the lab at the time.  This is where salting the roads stops working and also where you start to get black ice formation from exhaust condensation, so it's handy to know when you're driving in cold conditions.
32 and 212 (freezing and boiling points of water at standard (sea level) atmospheric pressure) is easy to remember - and the boiling point varies radically with altitude and barometric pressure so it makes little sense as a "magic number" for mnemonic purposes.
« Last Edit: October 26, 2009, 01:16:25 PM by Ungrounded Lightning Rod »
Re: water volume
« Reply #17 on: October 26, 2009, 05:17:54 PM »
Cool!
I had No idea, and I thought I knew all kinds of trivia stuff.
That is something I will remember for a long time.
« Last Edit: October 26, 2009, 05:17:54 PM by ghurd »
