Junkie;
Just keep in mind that any mounting system should not compromise strength.
Be a shame to see them cartwheeling across the landscape in a windstorm shedding panels as it goes.
Had an experience with some Siemens SP75 75 watt panels I had leaned up against a pine tree to test before installing. Got sidetracked a few minutes and a calm day became not so calm and they flipped onto the ground. Luckily the grass was shaggy and they landed softly.
Keep it in mind and good luck with it.
BTW mine are mounted on a 4" steel pipe in the ground and a Satellite dish actuator. A bit on the other end from your system size wise but just what I did. I would not personally use wood for several reasons like longevity, expansion and warping to name a couple but I often just use what I have if possible so I understand that.
There are 4 Kyocera 130 watt panels and 4 Siemens 75 watt panels on that rack.
Simple but requires welding and the dish polar mount hardware which used to be common in the throw away stream. I never worry about it blowing away and it is up out of the way. From a feeble memory I think the angle iron is 2.5 inch. I used Stainless screws , nuts and washers to isolate the aluminum panel frames from the steel. This is another gotcha that is not stressed enough steel on aluminum rots away the aluminum fairly quick so be sure any aluminum does not contact steel A SS nut works treat for this.
