I recently poured my rotor and the vinyl ester didn't set up on top of the coils. Here is what I did. After wiring up all of the coils, I put small patches of fiberglass on top of the coils and used vinyl ester to hold the coils together. The vinyl ester set up, but it wasn't strong enough to support the coils when I tried to lift it out of the mold. So I used some 2 part epoxy, and after that set up, I could lift the coils out without any problems. I poured the stator and after a few days, I opened up the cover only to find that the vinyl ester didn't set up wherever the epoxy was. The rest of the stator set up fine. So I mixed up some more vinyl ester and poured over the fiberglass patches and closed the mold up again. Well, after 3 more days in a 80 degree room, I opened the mold only to find that it still didn't set up. I cut the outer fiberglass ring that was above the coils, only to find that the 2 part epoxy was dissolved and the fiberglass patches could easily be lifted off. When I got the stator out of the mold, the bottom of the stator did the same thing, only not as bad. It seems that the vinyl ester will break down the 2 part epoxy. So, now I am not sure what to do. I dug out as much of the epoxy from around the coils as I can. Do I take a chance and fill up the voids with vinyl ester which may again react to the epoxy or do I just fill it with 2 part epoxy and cover it with fiberglass? The coils look fine after I removed the patches and the wires are all solid. I am sure if I can get it waterproofed, it will be fine. Any comments?
Here are a couple of pictures.
