Hello all,
With the snow piling up outside, and hampering other projects I've been drawn back to the electronics lab. I've had this idea on the back of my head for a while, but only now I've been getting started with it. So basically, it's a buck topology switching mode converter, that will take the input from the 3.2m axial flux generator, and convert it to the 12V battery bank. This should make the load maching much better, and increase energy yield especially in the average wind region. Currently the machine is, like the usual way, connected directly to the battery after the rectifier, which makes the loading curve awful.
The problem with the buck topology, that I've went with is, that the full power of the turbine always has to pass through the converter. The easier option controller wise would be to make the stator for a high cut in speed, and instead make the mppt contoller with boost topology, so it would boost the voltage proportional to the optimal loading curve, before the "cut in" point. After the cut in point, the current from the turbine would go directly to the battery, bypassing the converter. I think some forum members here have actually tried and succeeded in that arrangement, but can't remember at the moment who they were.
Anyways, as I wanted to avoid making a new stator, and as the furling currently is set at a quite low current (35-40A peak, continous current less than that) I went ahead with a buck style converter.
At first i started by designing the components for the power swither part. At the start i was pretty clueless, but it turned out once again in the internet there was more than enought resources available to design the components of the switcher. For the switching frequency I settled for a reasonable 100kHz, that i think was a good balance between passive component sizing & layout problems / switching losses. The attached schetcing shows the basic blocks of the converter, and the power components of the business end;
So, the system works by reading the speed from the turbine frequency (detail of this part is still unknown, it is one of the will be solved once we get there issues
), and then comparing the speed to a value in a lookup table loaded to the memory of the controller. The value in the lookup table will represent a power value for the current speed, and from that, based on the battery voltage, the desired output current is then calculated. The desired current is then, along with the current feedback, is then fed into the tl494 pwm controller, which in turn will control the pulse width going to the switching transistors. The fet gates are driven with an isolating gate transformer, which should provide some noise rejection to the contoller board, i hope.
Currently the power part of the controller is quite finished, but i've yet to test it at full load, so far I've only teased it at mild 10A loads... For the full load test i think i have to go with the mig welder
. The controller board is also quite nice in progress, but the speed measurement part is still totally untested, and the tl494 + it's accessories need to be tested further for stability. But if all goes well, i think it will be ready for real life testing once the snow will start to thaw away =). And even if it turns out to be dud in the end, at least i had fun while playing with it.
