Author Topic: How wood burners work  (Read 2558 times)
rosie
« on: December 13, 2004, 04:16:54 PM »
Is there someone here who can explain how a wood burner works?  On the basis that fire needs heat, fuel and oxygen to burn they are quite logical, but I am used to open fires.  At a friends house last night, I watched them operating their wood burner, which appeared to involve putting a giant log on a bed of glowing embers, and shutting off the air supply.  A few minutes later the log was on fire.  I now see that closing the shutters still allows a small air flow in, but on any normal fire, there is no way you are going to make a fire out of embers and a log.  You need newspaper or kindling, or anything that easily combusts.  I just don't understand how a log (and this was a big log!) can catch fire, when all the odds seem so heavily against it doing so.
« Last Edit: December 13, 2004, 04:16:54 PM by (unknown) »
whatsnext
Re: How wood burners work
« Reply #1 on: December 13, 2004, 09:41:44 AM »
O2 + wood + heat = fire
I've personally seen giant, wet stumps burst into flames when tossed on to a bed of hot coals so I'm really not sure what sort of answer you're looking for.
John.........
« Last Edit: December 13, 2004, 09:41:44 AM by whatsnext »
finnsawyer
« Reply #2 on: December 13, 2004, 09:44:36 AM »
There is enough heat in the embers in contact with the log to cause that part of the log to get hot enough to vaporize the volatiles in the wood.  These gases are in turn combustible and when coming in contact with the embers they burst into flame.  The burning gases then generate enough heat to burn the carbon (charcoal) that's left.  See Nothing-To-Lose's posting on his generating of wood gas.
« Last Edit: December 13, 2004, 09:44:36 AM by finnsawyer »
Ward
« Reply #3 on: December 13, 2004, 11:08:28 AM »
Also remember that the air is introduced under the bad of coals,  Unlike an open fire where it comes over the top of the fire.
Ward
« Last Edit: December 13, 2004, 11:08:28 AM by Ward »
« Reply #4 on: December 13, 2004, 12:07:21 PM »
It's all the same fire rather open camp fire or closed up in a wood burner.
The only reason you need kindling to start a fire (sticks, paper, leaves) is to make enough heat to start the logs burning really. You all ready have that in those glowing embers (hot coals). The fire is all ready burning your just adding more fuel to it when you toss in the new log. You just close the damper on the wood burner to adjust the air/oxygen the fire is getting to control the speed of the burn.
" but on any normal fire, there is no way you are going to make a fire out of embers and a log.  You need newspaper or kindling, or anything that easily combusts. "
You are mistaken there. By embers I geuss you mean hot coals after the other logs have burned down. Any open fire like a camp fire will do the same thing. Burn some logs till they are down to just alot of hot coals and toss in a couple of dry logs. Really dry pine is a good example or oak. Pine will often almost start burning soon as you toss it in, oak my sit a minute or so. Fresh cut wood will be wet and may be hard to burn.
Also in the wood burner the heat is contained in a smaller area somewhat and that will bake the log faster than an open fire of the same size will. An open fire just lets the heat out any direction as fast as it wants to go. In the wood burner the heat can only get out as fast as it can radiate through the sides or flow up the exhaust, so the log is actually surounded by more heat than an open fire. That may help the log to start faster. Sort of like frying something on top of a gas stove or baking in the oven. Baking is surounded by heat like a wood burner, frying only has most the heat at the bottom like a campfire some up around the sides.
As mentioned, the heat from the coals drives out the the impurities in the wood. Mostly flamable gases, water as steam, tars and resins ect as smoke. All that is needed is heat to bake out the flamable gas (methane I beleave) and oxygen to let it burn. It needs to be ignited somehow and the hot coals do that normally. With my charcoal maker that was mentioned, I had a 55gal barrel of wood being baked by a hot fire under it. The gas came out the pipe on top away from the fire so it was not burning. I had to lite that gas with a burning stick then it burned with a nice large flame. No air could get into the barrel where the wood was baking so the charcoal could not burn since it had no oxygen.
That's basically all any fire is except the coals burn up also since they are exposed to air. Anytime you see a flame that is the gas burning as it escapes the solid wood peice, the solid wood itself is the glowing hot coals and ashes you end up with. The smoke is steam, tars, resins, that don't burn.
In some cases maybe the gas will not ignite on it's own from the hot coals. Normally there is alot of small little flames flickering inthe coals and that lights the gas. Sometimes however there may just be hot coals and no little flames and the gas still bakes out of the wood it just does not burn. In that case you still have the same fire and burning the wood, but without flames.
Cardboard boxes are a good example. When we have pizza boxes (and others) I toss them in the wood burner. Pizza boxes make great heat for a short time. Most of the time they hit the hot coals and sit a second then burst into flames. The coals bake the gas out of the cardboard and the little flames around the coals light the gas. Sometimes there are no little flames or the gas comes out of the box far enough away from the flames it does not light. I get smoke and charred boxes baked into coal which will glow red and burn away to ash, but no flames. If I stick a match in when that starts to happen I get a nice poof as the gas lights and then I get alot of flames untill all the gas is baked out then the charred boxes glow red till turned to ash.
Another thought to is it's all the same thing, just larger or smaller. A tiny stick is a baby log, or a log is just an over grown stick. Paper or cardboard is just a processed log. They all burn the same way, some just take longer than others.
 When I just want the flamable gas quick and don't need charcoal I will probably bake  cardboard boxes. They contain lots of the gas are dry and will bake faster and still produce charcoal peices I can use for other stuff.
« Last Edit: December 13, 2004, 12:07:21 PM by nothing to lose »
bob golding
« Reply #5 on: December 13, 2004, 04:10:42 PM »
mmm interesting, i like the idea of baking cardboard boxes. they are a real pain to get rid of. cant put them in the paper recycling box, and dont like just  sending them to the landfill . one thing about woodburnibg stoves is the top plate to  reheat the smoke on the way out. this is important if you burn wood in a coal burning stove. put a plate between the flue and the fire to increase the path of the smoke going  into the flue.
bob golding
« Last Edit: December 13, 2004, 04:10:42 PM by bob golding »
« Reply #6 on: December 13, 2004, 11:01:39 PM »
the coals are the hottest part of the fire..............
« Last Edit: December 13, 2004, 11:01:39 PM by hiker »
skravlinge
« Reply #7 on: December 14, 2004, 04:04:48 AM »
Then not burning  in high temperature, your emissions will be high, and you not use the wood at the best. In a "cold" fire you produce dioxines (or what yiu call it), a potent poison. It is therefore not only economical reason to burn  so hot as possible, and use a accumulator tank.
« Last Edit: December 14, 2004, 04:04:48 AM by skravlinge »
« Reply #8 on: December 14, 2004, 10:14:46 AM »
Also, open fires are generally made with 'whatever' wood. Whatever was laying around rotting in the mud and rain close to the fire.
People heating with wood are using a well seasoned, dry, nice burning wood. It starts eaiser.
« Last Edit: December 14, 2004, 10:14:46 AM by ghurd »
Shadow
« Reply #9 on: December 14, 2004, 07:20:56 PM »
Something else to keep in mind, slow burning fires over a long period of time can cause build up of soot and creosote, a good way to keep that from happening is to get a good hot fire going on a nice breezy day , you'll clean the inside of your wood stove and the chimney, as  good as you can with a wire brush.On ours we notice the glass in the door will start to blacken over, we can clear that up in no time with a hot fire.
« Last Edit: December 14, 2004, 07:20:56 PM by Shadow »
alcul8r
« Reply #10 on: January 12, 2005, 07:41:57 AM »
I realize it's an older thread, but one thing left out is the reflection of heat by the walls of the wood stove.  Normally one log will not burn by itself, but in many wood stoves it will due to the reflection.
An old saying:
The two should be close enough for warmth, but far enough apart to breath.  Same for wood fire or marraige.
« Last Edit: January 12, 2005, 07:41:57 AM by alcul8r »
