Author Topic: fresnel hot water  (Read 1439 times)
joshua46v10
fresnel hot water
« on: April 13, 2006, 08:51:22 PM »
has anyone thought about using a Fresnel lens (well a lot of them really) for the glazing on solar hot water panels, if so what were your thoughts. is it worth it.
« Last Edit: April 13, 2006, 08:51:22 PM by (unknown) »
picmacmillan
Re: fresnel hot water
« Reply #1 on: April 13, 2006, 02:55:31 PM »
hi josh..there has been lots of posts on this topic..just click  the search the board button on the right and type in fresnel..there is a whack of posts that will pop up...hope this helps...good luck on your project ..pickster
« Last Edit: April 13, 2006, 02:55:31 PM by picmacmillan »
alcul8r
« Reply #2 on: April 13, 2006, 08:40:20 PM »
Essentially, you are confusing heat with temperature.
Yes, Fesnel lenses are impressive when they set wood on fire by just passing over it.  No, they will not heat water better than the equivalent area of glass.
« Last Edit: April 13, 2006, 08:40:20 PM by alcul8r »
The Crazy Noob
« Reply #3 on: April 14, 2006, 05:24:49 AM »
That's true but the lenses allow you to use an area that is bigger than the actual collector and focus all the sunlight from the big area on the smaller collector and so the temperature of the water will be higher than without the lenses.
« Last Edit: April 14, 2006, 05:24:49 AM by The Crazy Noob »
Derek
« Reply #4 on: April 14, 2006, 06:33:55 AM »
Here's what I've noticed when working with fresnel lenses:
First of all, they are somewhat of a fire hazard for using with anything, so be careful.
Second, for it to really work, you will need to have your pipes at about half way between the lenses and the focal point.  This WILL make the area hotter obviously, but heres the thing.  If the lens is not Exactly aligned with the angled of the sun, the light may divert at an angle and miss what you are trying to heat, and then also completely shade the area you DO want to heat.
The only way I see a fresnel lense working there would be if you had a tracking system.  But I'd just stick with dual pane glass for the glazing.  I think a 2 by 2 foot area with glass with heat water more than just a single fresnel lense concentrated on a single point.
« Last Edit: April 14, 2006, 06:33:55 AM by Derek »
